Results 1 to 6 of 6
Thread: Bonnet Striker Pin Assembly
  1. #1
    Jedi Knight Lin's Avatar
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    964
    Thanks Thanks Given
    5
    Thanks Thanks Received
    10
    Thanked in
    I mounted my bonnet after a total disassembly and then restoration of my car a little more than ten years ago. I recall that getting things aligned properly was a bit fiddly. I am now installing a different bonnet (long story) and my photos, indexing holes and etc. are only somewhat helpful since the “new” bonnet doesn’t have the indexing holes and the alignment is a little different.
    I have the bonnet secured to the hinges and it seems to be fitting pretty well side-to-side and front-to-back. Of course, the front is a little low since the striker assembly is not yet mounted. Can anyone who has been through this offer any tips or suggestions on how to best proceed? Alternatively, pointing me to a reference on this subject would be great. There sure isn’t much of anything in the shop manual about it.
    Thanks as always!
    Lin
    1959 AN5 Bugeye - now with my son 😀
    1960 BT7 3000 MKI
    1987 Alfa Romeo Spider Quadrifoglio
  2. #2
    Yoda HealeyRick's Avatar
    Join Date
    Apr 2004
    Location
    Massachusetts
    Posts
    5,912
    Thanks Thanks Given
    16
    49
    Thanked in
    Re: Bonnet Striker Pin Assembly
    Lin,
    I've found it helps to get under the car and look up through the latching mechanism and try to center the cone from the striker pin in the hole on the latch. You may have to adjust the striker afterwards, but it should get you in the ballpark.
    Rick
  3. #3
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    964
    Thanks Thanks Given
    5
    10
    Thanked in
    Just a word of thanks to those who responded to my appeal for tips to install the striker pin assembly for the bonnet. I appreciate all responses but especially wanted to thank Roland Wilhelmy for reminding me about Roger Moment's article entitled "trial-fitting Individual Parts." Roger's suggestions about how to install the pin assembly are detailed and offer warnings on what to do to avoid problems.
    Kent Lacy suggested "covering the striker hole with tape. Run your finger around the taped hole until it’s visible. Put a drop of paint on the tip of the striker and close the bonnet slowly until the paint drop is in the center of the hole on the tape. Replace tape each time it’s not correct. Trust me you want it to work the first time." I did this and found this to be a great tip. The photo shows my first attempt, but I was then able to easily adjust the position of the pin to get it centered. The unlocking mechanism then worked perfectly on the first attempt. Thank you, Kent!
    Healey Rick suggested doing basically the same thing by getting under the car and looking up to see if the tip of the striker pin was in the center of the retaining plate, but while this would certainly work, the tape was very easy and probably more precise.
    Thanks to all,
    Lin Rose
    1960 BT7 3000 MKI
  4. The Following 2 Users Say Thank You to Lin For This Useful Post:
    John Turney  (11-19-2019), steveg  (11-18-2019)
  5. #4
    Join Date
    Oct 2014
    Location
    Western Canada
    Posts
    480
    Thanks Thanks Given
    3
    2
    Thanked in
    Installing the hood (bonnet) striker assembly was one of the jobs undertaken today on the 100-6 reassembly project. I recalled reading the tip above about putting masking tape on the lower part and paint on the tip of the striker. That method didn't work well for me, possibly because the paint used was too thin and ran off. A minor modification to the method solved the problem. It occurred to me that a dark colored grease would work in place of a heavier paint. A bit of grease on the fingertip, deposited on the outer circle of the upper striker, did the job well. It left a nice circle on the masking tape, showing exactly the direction and amount of adjustment required for an accurate meshing of the upper and lower parts. Locked and released well the first time the hood was pushed down all the way.
  6. #5
    Join Date
    Apr 2002
    Location
    Bradenton, FL
    Posts
    964
    Thanks Thanks Given
    5
    10
    Thanked in
    Blue skies,
    I am sure grease will work, but rather than paint I used some of my wife’s nail polish. I used “That’s Berry Daring,” but I almost used “Blue My Mind.” It is just a matter of personal preference. Nice applicator and the polish is pretty thick, staying where you put it. Hah ha, chuckle, chuckle.
    Lin
    1960 BT7 3000 MKI
  7. #6
    Join Date
    May 2017
    Location
    Raleigh, NC
    Posts
    30
    Thanks Thanks Given
    1
    Thanked in
    Red lipstick from your girlfriend or mistress also works very well!
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
