red57
Hi all, I hope someone has done this and can help.
I found, after getting a Heritage Certificate for my '60 BT7, that it still had the original ingition lock with numbers that match the Cert. (the original key also has the same lock number stamped in it) and the same key works in the trunk lock - good news!
Bad news is the ignition lock body has been damaged by excessive heat and needs to be replaced, the other bad news is the trunk handle chrome is bad and the escutcheon is cracked so it also needs to be replaced.
Changing the lock barrel in the ignition is easy - with key in lock & turned on, there is a small brass button seen thru a hole in the lock body that you push and the cylinder slides out.
My problem is I there is no hole that I can see in the side of the trunk lock to press a pin inside - does anyone know how to change the lock barrel in the trunk lock? Do I have to grind the 'pinches' off the square shaft and remove the escutcheon to find a hole to access a pin? And, if I grind the 'pinches' off to disassemble, how di I re-assemble? I don't mind destroying the old handle and escutcheon to get the old lock barrel out but will I be able to reassemble the new latch and escutcheon with the old lock barrel in place?
I really would like to keep the original key that matches the Cert. and keep both locks keyed the same. I appreciate any help.
Thanks,
Dave
Thanks,
Dave
