The Roadster Factory Recovery Fund - Friends, as you may have heard, The Roadster Factory, a respected British Car Parts business in PA, suffered a total loss in a fire on Christmas Day. Read about it, discuss or ask questions >> HERE. The Triumph Register of America is sponsoring a fund raiser to help TRF get back on their feet. If you can help, vist >> their GoFundMe page.
Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
Hi Daniel, I'm moving this thread to our Austin Healey forum (I'll leave a "re-direct" marker in the New Members Intro forum) If you're reading this then you have been magically transferred to the AH forum.
Please do go back to the "New Members" forum and post an introduction of yourself.
I have rear discs on my '57 vintage racer, but find the drums provide plenty of braking power with the right pads on my '65 Bj8 for street perfromance driving. I did upgrade to balanced and vented drums which also eliminated the scuttle shake that occured at 60 mph.
Ventilated and balanced rear drums are an excellent alternative to modifying originals. I also have them installed on my BJ7. Considering a 4 pot caliper upgrade for the fronts now. GONZO
Gonzo - you won't be sorry you converted to 4-pots. Make sure the calipers fit your smaller (Type 14 IIRC) adapter plates. I believe they're available in both Type 14 and 16 bolt centers.
Edit: what selection of pads is available for the AHspares calipers? Do they use a pad design from a common car?
Cpnsidering the nose heavy condition upgrading the front is the place to spend your money. The rear brakes probably do not do a lot of the braking. Adding a lot of braking to the rear and not upgrading the front will cause a big balance problem.
Nobody asked me, but that's never stopped me before ... I have/had several cars with 4-wheel disks. None of them have, IMO, anything more than barely adequate parking/emergency brakes; both my Healeys, with the big drums in back--front, too for the BN2--have excellent parking/emergency brakes. Just sayin' ...
When I installed my front and rear discs, I had a conversation with Denis Welch about the front/rear balance. He said with the 1.5" piston diameter rear calipers and the 2.125" piston front calipers, proper brake balance can be obtained with proper pad selection.
John,
Did you pursue that avenue and if so, did you verify it with a panic stop?
FWIW before installing the proportion valve, I did a panic stop with my then-new 4-wheel discs and the car about swapped ends.
Richard Mayor (Boy Racer) gave me an easy method of setting the proportioning valve with the car on jackstands, which I'd be happy to pass along to anyone who wants it. The valves are around $40 and installing and adjusting them is a one-time-only task.
The DW system would call for different pads front and rear. If one changed front pads then maybe the rears would need to be experimented with for each change. The proportioning valve would call for the same pad composition front and rear.
I've been using the Centric Ceramic pads for several years with good unboosted pedal pressure and absolutely no squeaking.
My pointr egarding the rear brake conversion is that the drum brakes are probably sufficient and the dollars should be spent on improving the front brakes.
I am guessing that the fronts do 85-90% of the stopping.
Yes, they worked fine until I felt I needed to rebuild the brake system after 12 years and I put in the wrong master cylinder. My new rebuild includes the correct MC. I have to look through my records and find the correct pads (good ones in front, not so good in back).
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
