For Sale 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUNDLE
Steve Austin
F/S M3000 4 speed trans with OD in VERY good condition dry storage since 1985.... complete with clutch & bellhouse & flywheel
TRANS TAG 22/1709/007521 Laycock... bell # SG6855
Also 3 long block engines 29D BJ8 engines 3000 MK-1
Engine tag 290/RU/H1 5423
PRICE BUNDLE DEAL MAKE RESONABLE OFF.....
Have crates go'n to UK ... PU @ Dartford & Liverpool seaports.
pbraun
Re: 3000 BJ8 Laycock 4 speed with 22% OD trans & 2 6 cyln engines / long blocks / BUN
What is the price for the transmission if you don't mind me asking.
HOW MUCH?
maxwedge5281 Front Shroud Differences: 3000 vs. BJ8 Austin Healey 5
M 3000 BJ8 Door Seals Austin Healey 9
D For Sale 1967 Austin Healey 3000 MKIII BJ8 Austin Healey Classifieds 0
Patrick67BJ8 Early 3000 vs BJ8 vin Austin Healey 3
J 3000 bj8 Oil Pump Austin Healey 38
T Hardtop for Austin Healey 3000 BJ8 Austin Healey 34
S A few valve cover [rocker cover] related questions, 3000, BJ8. Austin Healey 9
S 1967 3000 MK3 BJ8 Suspension is so stiff - any chance to improve comfort ? Austin Healey 10
G Lens screw for AH 3000 BJ8 Austin Healey 1
davidb AH 3000 BJ8 overdrive problems Austin Healey 11
G Correct location of front turn signal on bj8 3000 Austin Healey 3
K 3000 BJ8 For sale in LA need PPI Austin Healey 17
memphis Panel Switch Wiring 3000 BJ8 Austin Healey 4
davidb AH 3000 BJ8 tachometer Austin Healey 10
H 1966 3000 BJ8 Heater Box Data Tag Data Info Austin Healey 1
H Need help with, 1966 3000 BJ8 WShield Post Install Austin Healey 2
B 3000 [not BJ8] Rear Springs - too stiff - why? Austin Healey 6
MadRiver BJ8 Center Console 3000 Badge Question Austin Healey 13
A Correct Color For BJ8 Radio Cover "3000" Badge ? Austin Healey 18
David_K AH 3000 BJ8 value and restoration? Austin Healey 9
K AH 3000 BJ8 restoration project Austin Healey 2
R 67 BJ8 3000 Tach Wiring Austin Healey 3
Z 3000 Front Wheel Bearings Austin Healey 3
G Custom-Bodied Austin-Healey 3000 Coupe Austin Healey 17
D Wanted: Healey 3000 MkIII body and chassis Austin Healey Classifieds 0
BoyRacer Engine Swap: 3000 Engine Into a BN1 Austin Healey 22
S Grill cowl top piece for AH 3000, BT7, $65 Austin Healey Classifieds 0
G Healey 3000 cutaway display engine Austin Healey 12
pbraun For Sale Healey 3000 transmission Austin Healey Classifieds 0
O HD8 carb on Healey 3000 Austin Healey 62
S For Sale Austin Healey 100-6 and 3000 Factory Service Manual on CD/ROM. Austin Healey Classifieds 0
S For Sale Austin Healey 3000 and 3000 MK II Factory Parts Manual - BN7 & BT7 on CD/ROM Austin Healey Classifieds 0
G 1960 3000 BN7 Top Help Austin Healey 0
C Austin Healey 3000 in Modsports Austin Healey 4
F After 30 years of ownership I decided to clean my 1961 Healey 3000 BT7 Austin Healey 0
C 1962 Healey 3000 Mark II Steering Box Austin Healey 9
Drone Dog 1962 3000 Hood/Bonnet Grille Austin Healey 5
maxwedge5281 Wanted wtb....bn6,3000 front shroud Austin Healey Classifieds 10
AUSMHLY 1962 3000 Mk II BT7 speedometer Austin Healey 2
B Wanted 100-6 or early 3000 upper and lower grille opening pieces Austin Healey Classifieds 1
A AH 3000 rear disc brake conversion Austin Healey 28
60TR3A Cost to Rebuild a Healey 3000 Engine [And Recommendations About Who to Do It] Austin Healey 14
B Max Dia for Cylinder Bore for a 3000 Austin Healey 5
M Wanted Healey 3000 Austin Healey Classifieds 4
lbcspinners 1962 Austin-Healey 3000 Mk II BN7 Tri-Carb 2-Seat Roadster: for sale on BaT Austin Healey 2
Marvin Gruber Most popular color for A/H 3000 Austin Healey 56
BN6 Healey 3000 Camshaft Identification Austin Healey 4
M For Sale Churchill 18G106 Valve Spring Compressor for Austin Healey 3000 Austin Healey Classifieds 0
S New Member 1967 Austin Healey 3000 Austin Healey 5
C For Sale 1965 Austin Healey 3000 MKIII Austin Healey Classifieds 0
