'74 Midget - Heater Box Bolt Size?
AngliaGT
It's been 3-4 years since I pulled it apart,
& not sure where I put the bolts to mount it to the
body.What size/thread are they?
And what size do the air outlets on the box use?
JPSmit
IIRC Doug the heater box is attached with sheet metal screws not bolts.
Jim_Gruber
JP, they are bolted in place 7/16 fine thread same size as the bolts holding on the cover plate over the ps footwell. At least on a BE that’s what they are.
dklawson
Jim, I assume you mean 7/16" across the flats which would have 1/4" threads (1/4-28 UNF = fine). 7/16 threads would be awful large.
Jim_Gruber
Doug, You are correct, 7/16” nut 1/4 28 bolt. I just chased those threads 2 mi utes ago. 1/4 28 tap
I prefer to use socket head bolts on those. And use anti-seize.
AngliaGT
AngliaGT
OK,I'm a little confused.Is there a nut?
Exactly WHAT do I need?
Rhodyspit75
You need a 1/4 x 28 bolt. I believe I used 3/4 inch long. The 1/4 inch bolt has a 7/16 head that’s where the confusion comes in.
jcatnite
I think the nuts are captured in the body of the car. All you need are the 1/4 -28 bolts and a washer. I think 3/4 long is what I used on the 76 midget. Haven't tackled the 74 yet.
AngliaGT 11/73 Midget MKIII - Heater Core Foam Thickness? Spridgets 10
BobMunch A couple Questions about later Midget heater cores Spridgets 0
C Looking for Heater switch / cable for Midget MKII Spridgets 4
G late model Midget heater hoses Spridgets 5
B Midget 1500 Heater core flow Spridgets 3
R 1500 mg midget heater hose Spridgets 10
G 1500 Midget Heater Valve Question Spridgets 21
77_MG_Midget heater hoses on a '77 Midget Spridgets 4
G mg midget heater valve Spridgets 5
J Midget Heater Controls MG 20
D Trying to get back working on the 1974 Midget Spridgets 10
C For Sale Selling MG Midget MG Classifieds 2
L Little1's 75 Midget 1500 Thread Spridgets 14
L Midget 1500 Zenith Air Filter Element: Is it a Unicorn? Spridgets 7
K 68 midget. No horn, headlights, turn signals Spridgets 9
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
K 1968 Midget Steering wheel Spridgets 1
K General MG 1968 Midget Questions MG 1
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
M 1500 Midget water pump weep hole Spridgets 2
M 1977 MG Midget 1500 Problem Spridgets 8
M Midget steering column Spridgets 3
B General MG 77 MIDGET Gas tank sending unit MG 1
shadowfever Midget seat nuts and bolts Spridgets 2
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
shadowfever Moss Motors MG Midget seat covers Spridgets 6
B 1977 Midget - Sandglow Paint Restoration & Tools 3
M Midget 1500 1977 Smog pump/Air Injection Pipe Spridgets 0
T MG Midget 1500 crank shaft pulley Spridgets 0
B For Sale '69 Midget MG Classifieds 0
M Wanted Midget 1500 exhaust manifold MG Classifieds 0
D I have doubled the value of my MG Midget. Spridgets 2
fordmstr 73 Midget rocker panel end caps and door handle gaskets advise Spridgets 3
A 78 MIDGET BUMPERLESS Spridgets 4
A 78 MG MIDGET EMMISIONS REMOVAL Spridgets 1
A 1978 MIDGET 1500cc engine oil leak Spridgets 4
A General MG 78 MG MIDGET ALTERNATOR SMOKES MG 5
D MG Midget 1275 rear oil seal. Spridgets 0
D Engine Colour for a 74 Midget. Spridgets 8
B 1977 Midget Bra Spridgets 9
B Midget Differential Capacity Spridgets 5
B For Sale Replacement Panels BE/Midget Spridgets Classified 0
G Best fuel option for a 72 Midget Spridgets 5
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
NutmegCT General MG MG Midget on Route 66 MG 3
D Back on the Midget after a vacation and work break. Spridgets 48
AngliaGT RB Midget - Finally tracked it Down! Spotted 3
AngliaGT For Sale MGB /Midget Wooden Shift Knob MG Classifieds 0
J Midget front shocks Spridgets 4
johntennyson Anyone Know These Guys? Or Remember Sprite-Midget Owners' Group? Spridgets 29
