G
Hi everyone - most of you probably remember my post a few months ago when my fan clutch separated from my water pump and really messed up my radiator. Well I replaced the water pump, fan clutch, plastic fan, and had my radiator rebuilt. I replaced some hoses (most were replaced by the previous owner) and detailed the engine compartment. It looks great.
Now for the not so good news. Everything is back together and I installed new antifreeze today and started the engine. Everything went fine. The engine is cool and sounds great. Then I noticed a small puddle of antifreeze under the car. It is coming from the heater valve. I don't think it leaked before but it leaks now. It is leaking from around the lever that is used to turn the valve on and off. Moss (part number 360-425) & VB say that the valve is not available. Has anyone else had this problem? Does anyone know if the valve can be repaired (it doesn't look like it comes apart)? Is there a replacement valve available? I can also remove it and either have the water circulate through the heater core all the time or I could bypass the heater core altogether. I would appreciate any advise or assistance. Thanks.
