Bonnet Latch/Release Adjustment
Chet Zerlin
Short story: Body shop did a great job on a repaint on my BN6. No issues at all with their work. To do the paint they of course removed the doors, the bonnet and the boot lid. Reinstall of all panels was excellent with even gaps, etc.
However, after many attempts they are unable to properly adjust the bonnet latch/release. Right now after it is fully latched when I pull on the cable release it releases, but something is stopping it from popping up all the way (it pops up just a little). To get it to fully pop up I need to hold the release cable all the way out while another person shifts the bonnet a little left and right and then it releases. Clearly something is catching or perhaps the spring is not strong enough or perhaps the cable has stretched and is no longer pulling it fully open?
Of course it worked fine before I took it in.
I'd really appreciate any advice or suggestions.
Thanks!
Chet
HealeyRick
Re: bonnet latch/release adjustment help needed!
It helps to get one person underneath the car looking upwards toward the latch to watch the engagement to give you an idea of which way to move the plate. I've found it's mostly trial and error with making small adjustments at a time until you hit the sweet spot.
C
Chet Zerlin
Problem solved! Body shop didn't give up and I guess did exactly as suggested. Kept playing with it until they found the sweet spot.
Bonnet release works fine now, car is back in my shop and ready for reassembly.
Thanks everyone!
Chet
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
Willie_P TR4/4A Tr4 bonnet latch bracket [highly technical] help! Triumph 6
Rut Front tilt bonnet latch Spridgets 40
S Jammed Bonnet Latch Jaguar 2
J Bonnet latch Austin Healey 3
angelfj1 TR2/3/3A TR3A Bonnet Latch Triumph 6
Rut Bugeye bonnet latch Spridgets 13
memphis Bonnet Latch Austin Healey 4
T Bonnet Latch Adjustment [how to adjust bonnet latch [BJ7] to keep it closed] Austin Healey 14
eschneider xj6 bonnet latch help Jaguar 7
B TR6 TR6 Bonnet Latch Cable/1972 Emission pic Triumph 31
Cain Bonnet Spring/Latch Triumph 4
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
CARSINC Sprite bonnet emblems Spridgets 4
J Wanted Hood (Bonnet) for a 1960 BT7 Austin Healey Classifieds 0
E TR6 TR6 flip-up bonnet question Triumph 4
KVH General Tech Fitting the Hood (Bonnet) Triumph 7
B Wanted Bugeye front bonnet fender mirror like this Spridgets Classified 5
Bayless Help please installing bonnet release cable Spridgets 8
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
LAW75 Bonnet Excessive Sway Austin Healey 6
M Wanted Looking for genuine Austin-Healey bonnet badge Austin Healey Classifieds 1
K TR2/3/3A The Louvered Bonnet? Triumph 2
J Wanted 1960 Sprite Bonnet Spridgets Classified 3
J Wanted Austin Healey Sprite Bonnet Austin Healey Classifieds 4
Pythias Sprite Winged Bonnet Badge.... ANYONE? Spridgets 16
mch979 1967 MGB GT bonnet issue MG 25
P MG TD Bonnet Upper Sections MG Classifieds 0
longbridgehealey Bonnet stay Spridgets 3
J Bonnet rubbing Spridgets 12
S Forward opening hood / bonnet Spridgets 10
R Mark III Bonnet Badge Austin Healey 9
F TR2/3/3A Bonnet safety hook Triumph 10
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
B Bonnet hinge gasket Spridgets 10
oldbagpipe SOLD!! Early TR4 Short Bubble [Bulge] Bonnet/Hood Triumph Classifieds 5
GeorgetheTR3 TR2/3/3A Bonnet popper, or something like that. Triumph 5
B Under bonnet fuel Austin Healey 15
charleyf TR2/3/3A Bonnet safety catch Triumph 0
4tecdog Fibreglass bonnet washer fittings Spridgets 5
D 1962 3000 Hood/Bonnet Grille Austin Healey 5
T Bruce Uchida Front Tilting Bonnet, 2008 Spridgets 10
Lin Bonnet Striker Pin Assembly Austin Healey 5
R bonnet hinge R or L Austin Healey 2
longbridgehealey Bonnet belt Austin Healey 16
longbridgehealey Removing BN4 Bonnet Austin Healey 9
CharlesBN1 need some advice fitting the bonnet on a 54 BN1 Austin Healey 4
