TR2/3/3A KAS-Kilmartin outer sills with bow to match door
Frank Canale
I am happy to announce that the pair of KAS-Kilmartin outer sills part #TR009 have arrived. This is the outer sill for TS60000 on that has the bow in the door. When i first opened them and took a look they did not look bowed but once the sill was clamped to the inner sill the bow was obvious. The flange that welds to the inner sill is straight but the outside edge is bowed. The bow is between 3/32" and 1/8". I have repaired the bottom of my doors and fabricated new door skins. These sills match the bow of my doors very well. I did not have the outer sill to go by when I did the repair so i am satisfied that the bow in the door is correct. There is one area that i am not sure about. The notch for the door clearance when it is open is different from the roadster factory outer sill. I have a pair of them as well so I am not sure which is correct. The roadster factory sills are straight and would need modification or body filler to match the door. Now to cost, each outer sill cost $ 87.91 Australian and $75.82 Australian to ship to the states. For the lads in the US that is each $63.29 and shipping $53.38 so roughly $90 dollars each, that is double what the big three are getting for theirs. Is it worth it, I think so, it is a difficult part to make with all the folds and trying to get the bow in it. I ordered the parts because My car has nothing in the middle for a reference so I was looking for a part that i thought would help bring the front and back together with some accuracy.
DavidApp
If I could go back in time I would have got them. I spent a lot of time messing with the sills the PO had fitted and still ended up with some bondo. I also added a strip to the first step in the sill on both sides because the gap at the bottom of the door was too big. $90.00 would have been a deal.
David
TomMull
+1 on David's comment. I am away from my shop so can't really comment on the notch except to say it looks right in the picture from my memory.
Tom
sp53
I think I would rivet the outer sill on and try and hang the door. The door rotation looks correct on the original one you have to me. My eyes are not good enough to see that little ¼ arch at the bottom of the door. However, I think where the little arc is going to come in play nice is where that little section of quarter panel by the stone guard is. The aftermarket outer rockers bulge out there 3/16 or maybe be bigger and look wrong. It looks like the ones you have pull back into the tub on that small section at the end of rocker where the door stops.
DavidApp
When I was at the stage of needing my outer sills held in place temporarily but firmly while I fitted other stuff I used self tapping screws. Held the bottom edge with clamps.
David
Tybalt Post-War Other Kas Kastner Triumph 3
aeronca65t General TR Kas Kastner Race - Summit Point Triumph 0
V 2012 Kas at Walter Mitty Triumph 8
V Kas to be Grand Marshall of the Mitty this Spring Triumph 5
MadMarx Eifelrace 2011 - Kas Kastner in Europe Triumph 4
MadMarx Kas Kastner book Triumph 8
M TR2/3/3A TR3 camahaft discovery [Kas Kastner D Grind] Triumph 13
M Kas Kastner's Site Triumph 14
DNK Kas Kasner prissy fit. Triumph 18
T kas kastner-book no.3 Triumph 6
Alan_Myers Kas Kastner books Triumph 4
T Kilmartin Adjustable Front Shock Mount Plates - Installation Instructions Austin Healey 0
T Kilmartin Healey 6000 Austin Healey 0
T Kilmartin Changing Ownership Austin Healey 2
HealeyPassion Kilmartin Front Suspension Gussets Austin Healey 4
Jake For Sale FS: BN1/BN2 Kilmartin Chassis Repair Parts, New Austin Healey Classifieds 2
55modified Anyone install one of these [100S Kilmartin pieces] for fresh air in your footbox? Austin Healey 14
T Kilmartin rear inner fenders Austin Healey 2
C Inner Sill Assembly Should i spend extra money on kilmartin brand??? Austin Healey 4
Patrick67BJ8 Kilmartin Radiator Fan Shroud Austin Healey 4
oxford kilmartin sills Austin Healey 1
A Kilmartin Parts [Sills] Austin Healey 5
C Kilmartin Sheet Metal parts availability Austin Healey 7
SNClocks Gap between inner and outer fenders Spridgets 0
newmexTR3 TR2/3/3A TR3 outer wishbone bushing removal Triumph 5
M TR2/3/3A Re-Assembling Rear Axle Outer Bearing and Hub Triumph 1
B TR4/4A Outer tie rods Triumph 8
69MGC MGC Replacing an Outer Wheel Well panel MG 3
dbenichou289 TR2/3/3A Headlight outer trim ring Triumph 6
red57 What is correct wire harness outer wrap Austin Healey 17
AUSMHLY BJ7-BJ8 outer weather strip for door window Austin Healey 4
Csarneson How do the outer sills [rockers] drain water? Austin Healey 7
J TR2/3/3A Outer Front Wheel Bearing Triumph 22
Lukens Outer rocker showing "rust" Restoration & Tools 11
D TR2/3/3A 7.68, outer tie rod Triumph 4
B Outer steering column connection to the steering box Austin Healey 6
H General Tech Door Glass outer seals installation Triumph 6
pkmh "Bearing Outer Race" Re-installation at Passenger Front Hub Extension Austin Healey 4
F TR4/4A TR4 inner and outer sills Triumph 2
MisterB Outer structure repair order/checklist Austin Healey 9
S TR2/3/3A outer sill and fan tail Triumph 11
red57 Outer Sill/Rocker fit problem Austin Healey 11
A Aligning New half front wing, outer sil and rear wing Austin Healey 5
T TR2/3/3A Requesting some picture of the outer Rocker panel Triumph 19
A TR2/3/3A 1959 TR3 Inner and Outer Rocker Replacement Bracing Triumph 10
M BT7 Outer Sill Replacement Austin Healey 2
T TR4/4A Outer tie rod ends - what's the trick? Triumph 7
H TR4/4A Outer door waist seal Triumph 5
britlover TR4/4A Anyone know a source for TR4-6 outer sills that actually fit? Triumph 13
S inner sills, outer sills, a post...where to start? Spridgets 28
