Mounting info needed for late BJ8 license plate holder
Anyone have a picture of the late BJ8 LP holder. I believe PO straightened the arms on the holder. I am thinking from where the plate in laying in the picture, keep the mounting surface where it it and bend the whole assembly straight up from there.
Healey Nut
Yes someone has severly bent /straightened out the arms of that bracket . I have an original the correct shape all sand blasted and primed in my parts boxes if you need one . I can take a pic tomorrow if no one else helps you .
Healey Nut
I think this is what your looking for Marv . This is original and ready for paint .
It is for sale along with a bunch of left over parts I have .
PM me if your interested .
Marvin Gruber
Exactly what I was looking for and what I expected to see. Will try my hand at bending it back, if not I will be getting in contact with you.
thx, Marv
BJ8Healeys
thx, Marv
Marv, BJ8s for North America from body number 79900 had the license plate bracket shown in Healey Nut's photos, but there was also another bracket where the license plate was actually mounted:
Haylett
Do you have any more pictures, from the inside of the bumper. I rearranged mine years ago and am having trouble trying to get it back to original!
grimes6
Hi Steve,
This link may help with all the parts needed for your installation.
[FONT=Verdana,Arial,Tahoma,Calibri,Geneva,sans-serif]https://lbcdigital.com/bmc_publications/akd3523/[/FONT]
dougie
I've always hated the way the '66-'67 BJ8"s had the plate mounted on the bumper. Another reason to love the 1965 BJ8 stylings.......
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
D TR2/3/3A overdrive cable routing: and mounting the drive train Triumph 31
B TR6 Gearbox mounting crossmember Triumph 10
F TR2/3/3A radio mounting plate Triumph 4
Branson box spridget grill mounting tabs / ears / brackets Spridgets 3
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
catfood BN1 Exhaust mounting Austin Healey 8
Basil E-Type fuel tank mounting bolts [$&^##$%*!!] Jaguar 16
G TR4/4A Silly Distributor Mounting Question Triumph 9
J Mounting 3000 engine to stand Austin Healey 7
