Results 1 to 20 of 20
Thread: What is the purpose of the brown wire on this steering rack?
Discuss the Austin Healey Sprite and the MG Midget. Two different but similar cars sometimes referred to collectively as the Spridget.
  1. #1
    Join Date
    Feb 2006
    Location
    East Tennessee
    Posts
    1,893
    Thanks Thanks Given
    Thanks Thanks Received
    Thanked in
    Ray N. Evans
    Oak Ridge, Tennessee
    1966 Sprite HAN8 60603
  2. #2
    Jedi Warrior BlueMax's Avatar
    Join Date
    Dec 2010
    Location
    Easley, South Carolina
    Posts
    713
    Thanks Thanks Given
    Thanked in
    Re: What is the purpose of the brown wire on this steering rack?
    Thats funny!!
  3. #3
    Join Date
    Aug 2011
    Location
    Frisco, TX
    Posts
    693
    Thanks Thanks Given
    3
    1
    Thanked in
    1 Post
    Probably an attempt to make sure the steering column is grounded so the horn will work.
    David Doan - Frisco, TX
    david at doan.us
    http://doan.us/blog/bugeye/
    1959 Bugeye - AN5L-26655
  4. #4
    Jedi Warrior Branson's Avatar
    Join Date
    Jan 2007
    Location
    OKC, OK
    Posts
    542
    Thanks Thanks Given
    Thanked in
    Grounded to itself? Electricity is a funny thing.
    BOOMER SOONER
    '65 Austin Healey Sprite MKIII
    street ported Mazda 12a
    Motortopia
    ebay listings
  5. #5
    Jedi Knight Keith_M's Avatar
    Join Date
    Aug 2012
    Location
    Logan, UT
    Posts
    979
    Thanks Thanks Given
    1
    Thanked in
    1 Post
    Quote Originally Posted by David_Doan View Post
    I think this is right. I seem to remember a wire from the steering column to the frame. I think this is just misplaced.
    Keith
    Keith
    '59 Bugeye (recently restored)
    '62 BT7 (recently restored)
    '65 Sprite (restored 30 yrs ago)
  6. #6
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Actually, there is a packing between the rack and the clamp that the ground wire attempt's to get around. Making the horn's work can be difficult. My 65 had a steel cable to ground that wrapped around the steering shaft when you turned. Appeared to be factory installed.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
    Working on quality rather than quantity
  7. #7
    Darth Vader Rut's Avatar
    Join Date
    Jan 2008
    Location
    Tuscaloosa and Orange Beach, AL
    Posts
    2,855
    Thanks Thanks Given
    23
    7
    Thanked in
    Quote Originally Posted by nomad View Post
    Kurt.
    With the steering rack electrically isolated by the packing between the rack tube and its mounts, this was their attempt to ground it for the horn. I painted my rack mount brackets and effectively insulated it and the horn didn't work.
    Rut
    Rut, '60 Bugeye, '70 MGB, '62 TR4, '66 TR4a IRS, '67 TR4a IRS, '68 TR4a IRS, '72 TR6
    When I went to school, they asked me what I wanted to be when I grew up. I wrote down 'happy'. They told me I didn't understand the assignment, and I told them they didn't understand life. John Lennon
  8. #8
    Yoda dklawson's Avatar
    Join Date
    Mar 2005
    Location
    Durham, North Carolina, USA
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    It may be a brown wire but for commonality with Lucas color codes it should be "black". As stated above, they are fitted to some non BMC cars (especially Triumphs) to make sure the horn circuit has a path to ground through the pinion on the steering column and the rack housing. On TRs there is typically a black wire from the front wiring harness that attaches to the rack with the other end connected to the chassis somewhere.
    Doug L.
    '64 Morris Mini Cooper-S 1275
    '67 Triumph GT6 Mk1
  9. #9
    Join Date
    Feb 2006
    Location
    East Tennessee
    Posts
    1,893
    Thanks Thanks Given
    Thanked in
    This horn grounding thing my be the root of all my electrical issues with the Whitephrog. It wasn't unusual for the horn to operate for no reason at all. I seem to recall the horn sounding occasionally when the headlamps were turned on. I believe that all this may have fried the ignition switch.
    Ray N. Evans
  10. #10
    I think ground on my 79 is brown
  11. #11
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    I believe that brown is supposed to be unfused hot. I'd have picked black, Doug. Unfused brown for the horn button circuit. Black after that.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
  12. #12
    Jedi Knight smaceng's Avatar
    Join Date
    Nov 2008
    Location
    Martinez, CA
    Posts
    1,150
    Thanks Thanks Given
    Thanked in
    So I had the same problem that others had....horn would not work. Maybe I was wrong, but I insulated with fish paper the rack from the frame mounts as the factory specification. I can understand why the factory did this as the rack is steel and the mounts are aluminum. I do not think there is a good ground through the tie rods...may be they are rubber insulated? So I did what is suggested, I added the wire from the rack to the bolt which attaches the rack to the frame. What I want to know....how in the world did the factory get the horn to work reliably ????? As designed it is hit or miss.....as other have indicated.....as well as myself!
    Any input would be appreciated. I think this is one of the only areas on my "old" 60FROG that I had to modify the factory design to make the car "operatehorn grounding.jpg."
    Scott in CA
    1973 TR6
  13. #13
    Yoda PAUL161's Avatar
    Join Date
    Jan 2005
    Location
    Locust Grove, Oklahoma
    Posts
    9,546
    Thanks Thanks Given
    1
    48
    Thanked in
    Not sure on Sprites, but Black is a Lucas standard for ground/earth. Brown is an, I think, unfused hot wire, with or without stripes. After all these years, who knows what's been changed on these cars. PJ
    Remember, Never Forget
    We Live In The Land of The Free
    Because of The Brave
    How good it feels, the hand of an old friend! Longfellow
  14. #14
    Darth Vader Bayless's Avatar
    Join Date
    Mar 2007
    Location
    Oklahoma City
    Posts
    2,665
    Thanks Thanks Given
    15
    Thanked in
    That's right. Brown is unfused hot and ground is black. Of course who knows what some DPO may have added.
    Was Man nicht im Kopf hat muss Man in den Beinen haben
    '48 Ford Prefect
    '67 Sprite (project)
    '74 Super Beetle
    http://enfoprefect.org
  15. #15
    I'll have to check but I'd swear all of my lights are grounded brown on my 79 and it's an original unmolested harness.
  16. #16
    Join Date
    Dec 2008
    Location
    South Dakota
    Posts
    3,932
    Thanks Thanks Given
    4
    Thanked in
    Quote Originally Posted by smaceng View Post
    Scott in CA
    Scott, my 65 Midget had a small steel cable that attached at the steering shaft to rack pinion pinch bolt and went to the rack clamp frame attachment bolt. As you turned the wheel the cable would wrap around the steering shaft. Sure looked to be factory original.
    Kurt.
    65,66 Midget
    57 Berkeley, MGA
  17. #17
    Obi Wan Sarastro's Avatar
    Join Date
    Jul 2006
    Location
    Long Beach, California
    Posts
    2,370
    Thanks Thanks Given
    1
    10
    Thanked in
    I've always seen black for grounds on LBCs. However, for what it's worth, Bosch created a standard for wire colors, which is used in my '67 Porsche, and I suspect most or all other German cars. Maybe other European ones too. In that standard, brown is ground. So, it's not a great surprise that someone might be accustomed to that standard and just automatically used brown for a ground.
    Steve Maas
    1966 Triumph TR4A, undergoing restoration: http://www.nonlintec.com/tr4a
    1952 MG TD, restoration completed 2014, sold 2016: http://www.nonlintec.com/mgtd
    1960 Austin-Healey "Bugeye" Sprite, sold 2010: http://www.nonlintec.com/sprite
    1967 Porsche 912: http://www.nonlintec.com/porsche
  18. #18
    Join Date
    Mar 2005
    Location
    Posts
    6,254
    Thanks Thanks Given
    52
    Thanked in
    For future reference, the link below is for Lucas wiring color codes. According to it, "In the United Kingdom the British Standard BS-AU7 determines colour coding of automobile wiring."
    https://www.mgb-stuff.org.uk/colourcodes.htm
    Doug L.
    '67 Triumph GT6 Mk1
  19. #19
    Jedi Hopeful histerical's Avatar
    Join Date
    Nov 2008
    Location
    South Salem,NY
    Posts
    183
    Thanks Thanks Given
    Thanked in
    Wow . That chart is a treat. Thanks.
  20. #20
    Great Pumpkin jlaird's Avatar
    Join Date
    Nov 2005
    Location
    Niceville FL
    Posts
    19,536
    Thanks Thanks Given
    Thanked in
    After looking at the pic several times, I think it is a trick question. LOL
    Jack Laird
    Retired USAF
    Miss Agatha. On the road again and smiling at her new Calif. home.
    Fourteen shows, Eleven firsts and counting we hope.
Bookmarks
Posting Permissions
  • You may not post replies
  • You may not edit your posts
