Whitephrog
Probably an attempt to make sure the steering column is grounded so the horn will work.
With the steering rack electrically isolated by the packing between the rack tube and its mounts, this was their attempt to ground it for the horn. I painted my rack mount brackets and effectively insulated it and the horn didn't work.Actually, there is a packing between the rack and the clamp that the ground wire attempt's to get around. Making the horn's work can be difficult. My 65 had a steel cable to ground that wrapped around the steering shaft when you turned. Appeared to be factory installed.
Kurt.
So I had the same problem that others had....horn would not work. Maybe I was wrong, but I insulated with fish paper the rack from the frame mounts as the factory specification. I can understand why the factory did this as the rack is steel and the mounts are aluminum. I do not think there is a good ground through the tie rods...may be they are rubber insulated? So I did what is suggested, I added the wire from the rack to the bolt which attaches the rack to the frame. What I want to know....how in the world did the factory get the horn to work reliably ????? As designed it is hit or miss.....as other have indicated.....as well as myself!
Any input would be appreciated. I think this is one of the only areas on my "old" 60FROG that I had to modify the factory design to make the car "operateView attachment 36279."
Scott in CA
