wiring of alternator
mesposito
I am in the process of changing my BJ8 from positive to negative ground. I have changed the fuel pump (electronic) and the points (Pertronix) and installed the new alternator. I will attack the Tach issue later. So my question is on the wiring of the alternator. I have the diagram that came with the kit from Moss. I have looked at the video that Moss has on its website. I am still confused. I have 2 wires coming from the alternator... the "D" wire which is a large wire and the "F" wire which is a small wire. I have traced them and they both go directly to the voltage regulator and are attached to the tabs marked "D" and "F". On the voltage regulator I have the following tabs "E" (for earth or ground), "D" (for Dynamo), WL (for warning light?), "F" (for field) and 2 tabs marked "B" (don't have a clue what the B stands for) with 3 heavy brown wires going to them. From what I have read and have seen on the video I am pretty sure that the "D" wire needs to be tied to the 3 "B" wires. I assume that the "F" wire and the "WL" wire need to be tired together. And then I am done. Is that correct? Am I missing something? As always any help is greatly appreciated.
Espo
'65 BJ8
steveg
Is this the Lucas alternator? Does it have an internal regulator? If so you're only using the old reg as a junction strip for the various wires. The reg is usually either gutted or all the fusable links on the bottom are cut. I ran a separate 10 GA wire from the alt to the cable connection on the solenoid.
If you use the stock 12 GA yellow wire to carry the current output, it joins to the 3 brown wires. The small yellow and yellow/green wires join - they're for the idiot light.
The wire for the field terminal comes from the ignition switch.
Suggest you add a voltmeter. The dash light doesn't do much of anything.
This is how I did it:
https://www.healey6.com/Technical/Alternator1.pdf
vette
Here is a diagram of the circuit I built into my BJ7. The "Main Bus" in the wiring diagram is the location of where the voltage regulator used to be. You can either remove the regulator and use a terminal strip as I did or you can cut all the connections to the regulator terminals on the back of the regulator. I figured why ruin a good regulator and I wasn't trying to fool anyone with my alterations. Simple is best to me. So I used the terminal strip.
A couple exceptions to the wiring diagram is that (1) don't bother to put in an amp meter. It won't record properly as I have it anyway. Just run the #10 red wire from the alternator "B" terminal to the "Battery" terminal on the starter solenoid. That gives you a much heavier wire for the charging current from the alternator to the battery.
Exception (2) is that I believe I mislabled the wire on the alternator marked 'R' or on some alternators it is marked '1". On my drawing it shows as yellow/brown I pretty sure it is really a yellow/green wire. Steveg above mentioned it as yellow/green and I go with that. (i really should change my drawing). As you can see at the regulator location where i use a terminal bar (main bus) this yellow/green wire is attached to the small yellow wire which goes to the ignition charge indicator light.
I have also attached two pics of my engine bay for you to see what the connections at the voltage regulator location look like in real life. I believe the pic a clear enough that you can pick out the wire colours there also. this wiring has been working in my BJ7 for 4 years now.
John Turney
Much depends on which alternator you have. If you have one like shown in this Moss Motors video: https://www.youtube.com/watch?v=4NsAYiUHsho, the two wires can be attached as Moss described. The fat wire goes to the "D" regulator terminal and jumpers are added between the "D" terminal and terminals "A" and "A1". The thin wire is tied to the warning light. All the other terminal are unused.
I have a GM 10SI alternator (used in the late 1970s to 1980s GM cars and trucks). It has three wires and is somewhat differently.
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
apbos Positive Ground Alternator wiring. Spridgets 9
BoyRacer Wiring question for alternator conversion Austin Healey 3
G TR2/3/3A Wiring ammeter with the British Wiring alternator conversion. Triumph 13
D TR2/3/3A Alternator wiring diagram Triumph 7
T TR2/3/3A Question on wiring Denso alternator through ammeter Triumph 4
K TR2/3/3A Triumph Rescue/British Wiring Alternator Kit Triumph 10
N Spitfire alternator wiring question Triumph 1
K TR2/3/3A Alternator from British Wiring Triumph 12
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
Lukens TR2/3/3A Help wiring convertion alternator Triumph 6
B TR6 Does a 75 amp alternator require a wiring upgrade of any kind? Triumph 3
bash Alternator wiring question Triumph 5
D MGB mgb 77 alternator wiring. MG 2
Patrick67BJ8 Alternator Conversion & Regulator Wiring Help Need Austin Healey 11
H TR4/4A tr4 alternator wiring Triumph 4
I Alternator wiring Austin Healey 5
E BE Alternator Wiring Question Spridgets 5
T TR4/4A TR4A alternator conversion wiring question Triumph 28
tweety Alternator wiring connector, Sources? Spridgets 4
G MGB Alternator wiring "71 MGB MG 4
bill_powell Alternator Conversion / Wiring Spridgets 13
kodanja Alternator upgrade wiring? Triumph 30
kyreb1862 MGB 77 MGB Alternator Wiring MG 4
B TR6 71 TR6 Alternator Wiring Triumph 2
Webb Quick Alternator Wiring Question Triumph 3
Airfix TR6 TR6 alternator wiring? Triumph 5
D Alternator Wiring MG 7
C Wiring Check. Alternator wiring. MG 19
LastDeadLast Bosch Alternator Wiring Question Triumph 1
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
