Hi Bill,
If you choose to replace the studs, I believe they are threaded into the hub, and they are often peened a little on the inside to prevent loosening. It's a matter of grinding off the peened area slightly, so the threads in the hub aren't damaged when the the stud is backed out. (Note: if the thread gets damaged, there are repair kits sold by one or two of the Triumph vendors that use an oversize thread in a freshly tapped hole in the hub. The end that mounts the wheel or wire adapter stays the same size & thread.)
The spacer isn't very thick, only about 6mm or 1/4" approx. (
www.revingtontr.com has the best).
Or, just use a Dremel tool to cut off the existing studs. Dremel *reinforced* cutoff disks will make pretty quick work of cutting them.
Best way to do this is to install the adapter to the hub, being sure it is very clean metal-to-metal contact, or it might work loose. Use only the special lug nuts, not the regular ones. Tighten them up and then cut off the studs leaving about 1 thread protruding from the lug nut.
The adapters are left and right, used incorrectly the spinners will come loose.
One thing that you might want to consider, wire wheels are pretty heavy, and the adapters add even more weight. This does effect handling, since it's unsprung weight.
Wires are also a pain in the rear to clean.
On the other hand they sure look great!
Also, I recommend not buying used wire wheels or hubs, only new. An unknown set of wires or hubs might be getting replaced and sold off because of problems. The primary reasons are that the wheels sometimes need truing and the splines on both the wheel and the adapter do wear over time. It's hard to spot either of these problems by eye, no matter how carefully a used set is inspected.
Have fun shopping!
