Windshield Installation?
Bill Tubbs
How the heck do you install the dang windshield on a 79 Midget? I tried for several hours a few months ago and gave up for a while. Now that the car may be back on the road pretty soon, I need to get serious.
I put a new gasket under the replacement windshield I have and that may be part of the problem. But I get two bolts in one side with very little problem and then can't get the other side to line up for the next pair. What's the secret? I MUST be missing something. Help!!!!
Bill Tubbs
https://tubbs.cc/mg
Lurker
You are having some fun! Went throught the same thing with my B.
What worked for me was a c-clamp. Open the door on the side that you can not align and place the clamp so that one side is on the windshield frame pushing in, and the other side is in the door jam. On my B there is a diagnal surface in the door jam that looks like it is meant for this use. SLOWLY apply pressure with the clamp until the holes are close enough to being aligned to start the bolts.
Oh, yeah. On the side that you can start the bolts without the clamp, leave them loose until you get all the bolts started.
Yes, found the windshield experience to be the biggest pain in the neck as far as MG maintenance goes. Much rather put in a new clutch that mess with the windshield.
Good luck.
captobvious
There was actually a tip about this in Moss' "British Motoring" magazine recently. It's actually for an MGB, but the Midget's windshield setup is almost the same. To be fair it comes from Larry Dale of Richland, WA.
He had the same problem you are having, and what he did was drill out the three rivets which hold the cover plate in place over the two bolts on each side of the car. After replacing and tightening the bolts, he riveted the cover back in place. It seems it really simplified the job...
I will be replacing the inner windshied seal on my '67 Sprite pretty soon and may try this trick...
B
Bill Tubbs
You know, I saw that trick with the C-clamp on a web site but not being familiar with the MGB, it looked in the photo as if the B was configured a bit differently. But for the price of a clamp it sure can't hurt to try!
Thanks!!
simon1966 Windshield Installation on BN1 Austin Healey 10
C Windshield Installation problems Austin Healey 6
C windshield installation Spridgets 7
sqbsprite TR6 Windshield Installation - on or off the car? Triumph 11
J BJ8 windshield-shroud seal installation-found way to help keep ends from popping out Austin Healey 1
P XKE series 1 FHC windshield installation ?? Jaguar 4
I TR6 Windshield washer jets...placement and installation Triumph 1
B Windshield rubber to body installation Austin Healey 22
Stinger TR4/4A TR4A Windshield Installation Question Triumph 7
L Bugeye windshield glass installation Spridgets 13
R Windshield installation. Help needed Triumph 9
Ohiobugeye Bugeye Windshield Wiper Installation OUCH !!!! Spridgets 3
J blew the windshield installation Austin Healey 4
T Windshield installation???? MG 6
B Windshield installation BN6 +7 , BT7 Austin Healey 12
dklawson Spitfire Spitfire Windshield Installation - Mk4 Triumph 4
R Windshield Installation Austin Healey 7
regularman Any windshield installation tricks, tips? Spridgets 17
jhorton3 Windshield Installation Spridgets 3
77_MG_Midget Windshield installation The "EASY" way. Spridgets 4
77_MG_Midget Windshield installation help Spridgets 11
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
D TR2/3/3A Windshield glass doesn't fit Triumph 6
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
D TR2/3/3A Windshield assembly question Triumph 6
drooartz Replacing Bugeye windshield rubber Spridgets 6
K TR2/3/3A Removing scratches and scrapes fro the wind wings that screw to the windshield? Triumph 9
ModifiedBJ7 BJ7 Windshield Surround Rubber Seal Austin Healey 2
T TR2/3/3A TR3A Windshield Question Triumph 4
Popeye General TR Old imperfect windshield - keep it toss? Triumph 3
Popeye For Sale Original TR4A windshield - with crack Triumph Classifieds 1
K TR2/3/3A Removing TR3 windshield stanchions Triumph 4
P Austin A40 Devon windshield. British Motor Corp 2
K TR2/3/3A The Harley Davidson side mirror that mounts to the TR3 windshield stanchion? Triumph 11
R TR2/3/3A Windshield Wiper System Triumph 2
P Cracked windshield Other Cars 0
B TR4/4A Windshield Capping Strip Triumph 5
D TR2/3/3A Windshield frame fitting. Triumph 2
M TR6 Windshield Trim TR6 Triumph 14
Sopwith_Camel mk2 windshield wiper nozzles Jaguar 4
Michael Oritt 100 Windshield seal Austin Healey 0
S Bugeye Windshield Seal Austin Healey 1
BoyRacer Windshield Wiper Wheelbox Austin Healey 4
EWD TR6 74 TR6 - Rear and windshield frame color Triumph 2
B Windshield glass, where to buy Restoration & Tools 4
S TR2/3/3A Cutting the finish end on the windshield top rubber Triumph 4
C MGB 1966 MGB windshield glass MG 4
M General MG Midget MK1 windshield replacement MG 2
B MGA Windshield glass MG 11
R TR2/3/3A Fitting windshield Triumph 3
