TR2/3/3A What is the distance from the rear overider to the body.......
karls59tr
Bronze
measured from the top of the overider to the body. I've seen a lot of variations on different TR3's depending on what type of vehicle has tapped the bumper.:smile: How big was that space when they left the factory?
martx-5
Mine must have got hit pretty hard in it's earlier life...they measure about 2" away. :grin:
trglory
They were not known for precision back then. There may be more than one "right answer". The overrider brackets go through a body tube and attach to the frame. If the frame is straight and the body tubes are undamaged, compare the two brackets to see if you can detect and differences. Other possibility is that the contour of the rear fascia may have been "altered". Take a few data points with a straight edge and plumb line.
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
Carlos TR4/4A Moss rear spring distance piece 674-560 Triumph 16
Popeye TR4/4A TR4A rear leaf spring distance piece Triumph 11
K TR2/3/3A TR4 rear leaf spring "distance piece"? Triumph 1
B TR4/4A TR4 Rear Leaf - Do I need distance piece? Triumph 5
K TR4/4A TR4A Distance between trunk lid and rear overiders Triumph 5
M_Pied_Lourd TR2/3/3A TR3A Rear Bumper Distance Tubes Triumph 11
MikeAH100M 100 Front Hub Spacer/Distance Piece Austin Healey 2
BN6_2197 Question on tools and spare parts for lonng distance drive Austin Healey 28
R General TR Long Distance Trip Repair Kit Triumph 20
K TR2/3/3A Distance from center wheel hub to center wheel hub? Triumph 6
BN6_2197 Distance Peace bearing for BN6 with whire wheels Austin Healey 10
JPSmit What is that strange grinding sound in the distance? Spridgets 3
DanLewis Distance between mechanical fan and radiator core Spridgets 17
CanberraBJ8 "distance piece" in under tea hub nuts? Austin Healey 3
H 4.2L distribitor drive distance/thrust washer Jaguar 0
germanmichel Distance hardtop/ top positioning guiding sleeves Austin Healey 12
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
T Wish me luck - off on my first distance rally Triumph 11
jjbunn Pedals: fore and aft distance Triumph 10
Banjo long-distance Lucascism Triumph 33
bluemiata90 Buying car long distance, how should I do this Triumph 23
D Dynamo - distance between mounting faces Austin Healey 5
G TR4/4A TR4 DISTANCE PIECE between axle and leaf Triumph 4
Daimlerdb18 MGA MGA 1500 generator shaft distance piece MG 8
kennypinkerton Long distance car buying? MG 11
petnatcar Rear View Mirror Relocation Austin Healey 0
Carlbanan56 MGB Rear axel torque? MG 4
trbby2 TR4/4A TR4A Intermittent rear wheel locking? Triumph 19
Carlbanan56 MGB Rear wheelbearing clicking MG 8
Carlbanan56 MGB MGB rear break rebuild MG 6
bigjones TR2/3/3A Rear tail light not budging Triumph 5
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
Michael Oritt Rear Crank Seal Kit Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
O Jaguar rear window trim repair Jaguar 1
Joel Lester TR2/3/3A Is "later" style rear view mirror taller than the "early" style? Triumph 6
S Leaking HD6 Rear Carb Austin Healey 10
Joel Lester TR2/3/3A Do rear leaf springs wear out? Triumph 11
J TR2/3/3A Rear Fuel Line Clips Triumph 3
60BN7 Rear Wheel Opening Austin Healey 9
