Well, the floats weren't stuck...
Gabe,
I would back flush the lines with denatured alcohol from the engine compartment to the tank fitting. You could pour the alcohol into the lines using a funnel and hose and blow in air from a filled innertube or air tank or you could fill up an old gear oil bottle with alcohol and just squeeze it to provide the pressure to wash down all the old stuff. I'm sure you'll come up with something. Ingenuity is the mother of invention, right? Good luck with it.
Dave
R BT7 Carb floats Austin Healey 1
N Floats and needle valves Austin Healey 14
R GT6 Carb Floats for Stromberg 150 . Triumph 5
Geo Hahn TR4/4A Floats in TR4 ZS Carbs Triumph 5
dklawson Early Stromberg Floats - 150CD Triumph 5
dklawson 150 CD Carb Floats - Early vs Late ? Triumph 2
jdubois Anybody tried these floats? Triumph 7
Marvin Gruber XKE Fuel floats Jaguar 7
Jim_Gruber Smell of gas, turns out not floats set too high Spridgets 4
G Carb floats SU HS4 on triple carb AH BT7 Austin Healey 10
K Sticking Floats Triumph 12
amcboy Mmmmm Carb Floats... And a request for opinions.. Triumph 10
T sticky floats? Austin Healey 30
middleagecrazy HS2 floats Spridgets 9
Michael Oritt Nitrophyle foam for floats Austin Healey 2
goloch Floats, AGAIN?!??!?!??! MG 2
M Carburetor Floats Austin Healey 8
Andy Blackley TR4/4A TR4 Stromberg Floats Triumph 2
Jim_Gruber I think I know why the rear brakes weren't exactly doing their job. Spridgets 9
AH100M Why weren't sill and wing flanges painted black on BN1s and BN2s? Austin Healey 12
B TR4/4A AC Fuel Pump Priming Lever Stuck Triumph 14
R Healey 100 Dipstick Stuck Austin Healey 12
DrEntropy General MG Stuck splines? MG 3
S TR2/3/3A engine and trans are stuck together pretty well Triumph 8
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
KVH General TR Shifter Stuck Triumph 6
S TR2/3/3A Removing a stuck oil drain plug Triumph 13
L Stuck in Overdrive Austin Healey 10
M General Tech J Type OD Stuck in OD - Fixed Triumph 2
A MGB Stuck water temperature sensor MG 26
Rut TR4/4A Stuck clutch, again Triumph 19
TomMull Using my press to remove stuck Girling caliper pistons Restoration & Tools 13
K TR2/3/3A High beams seem to be stuck on when the headlights are turned on? Triumph 3
C Side-Change Gearbox Stuck in Top Gear Austin Healey 43
F TR2/3/3A I'm stuck... alternator/wiring/starting/? Triumph 2
R TR2/3/3A Help, I am stuck, or think I'm stuck Triumph 32
J TR2/3/3A Oil drain plug stuck Triumph 10
drooartz MGB Stuck in now, engine swap time MG 13
N Stuck Needle Valve - Rough Running Austin Healey 15
M battery helmet stuck on post help Austin Healey 8
JimLaney 1098 stuck lifters problems Spridgets 5
Michael Oritt Oil release valve plunger stuck Austin Healey 9
HighAltitudeTR3 TR2/3/3A What is non magnetic metal and gets stuck in Pressure Relief Valve? Triumph 48
D TR2/3/3A engine :"stuck" even before it starts! Triumph 28
D TR2/3/3A Exhaust pipe flange stuck to manifold Triumph 5
nevets stuck rear brake drum Austin Healey 18
D TR4/4A badly stuck suspension sleeves Triumph 7
jfarris TR2/3/3A Head stuck on block Triumph 8
R General Tech Pressure Plate Stuck? Triumph 5
R Pressure Plate Stuck? Austin Healey 3
