Voltmeter Wiring Diagram Wanter
Patrick67BJ8
I'm hooking up my Voltmeter in my Neg. grd BJ8 and want to know if anyone has a Wiring diagram they can post or PM me?
thanks
Michael Oritt
Patrick--
Usually volt meters have only two contacts (not counting lighting). One goes to a positive source switched by the key and the other goes to a ground.
Patrick67BJ8
Patrick67BJ8
Patrick--
Yep, I looked it up on a Hot Rod forum. I'm good. Thanks!
dklawson
If you have a voltmeter (not an ammeter) you shouldn't require a proper wiring diagram for hooking up the gauge.
If it's a Smiths gauge, either gauge terminal can be connected to chassis ground (preferably with a black wire), the other terminal connected via a green wire to any green wire you find behind the dash. If the gauge is a brand other than Smiths, the GND gauge terminal (perhaps a black wire) goes to chassis ground. As before, the remaining gauge terminal gets connected to any existing green wire behind the dash. Fuses are optional. If you want one, put it inline with the wire going to the car's green wire. Use something small, like 3 Amps.
Illumination can be one of two colors, red or red/white. Look for existing illumination bulbs behind the dash and splice your voltmeter's lamp wire into one of those wires.
Green wires are switched, fused wires in Lucas schemes. Connecting your voltmeter to a green wire means it will only be powered up when the ignition key is in the run position.
If you really meant ammeter, that wiring is totally different.
gonzo
Patrick,
After my recent Dynamator alternator negative ground conversion I wanted to monitor charge, but I also wanted USB device charging capability so this little device was discreetly installed. It's sufficiently accurate too. Dynamator charges (13.8V) at around 800RPM and puts out 12.8V at idele 550 - 600. GONZO.
Keoke
gonzo,
Where did you find that little goodie???:angel2:
gonzo
Keoke,
Me GONZO. Litt'l goodie found on Amazon.com Diameter is 1.1'' but found discreet place underdash tray to install.
Patrick67BJ8
Patrick67BJ8
Its a Smiths Gauge. Lighting Wiring was done to red/white as original. Black ground as original. I'm undecided as to a green wire going to the switched fuse panel or a white wire from the ignition switch. When I craw under the dash tomorrow I'll make up my mind. Console and trans out right now so I have a Board across the floorboard with comfy cushions which should make the job easier. Clock hooked up yesterday with a green/red wire. I want to think out connection of clock because I want it to run with the battery switch turned off. Heater Boost switch now provides manual electric fan operation, but I still have a parallel circuit for thermostatic control of the engine fan. (I have Austin AC system).
steveg
Patrick,
Do you run it without the cover so you can see the voltage?
dklawson
The easiest way would be to run a wire from the clock to the "always hot" side of the cutoff switch.
On the Mini I have a battery cable disconnect. I have a 5 Amp fuse wired in parallel to the disconnect. That allows me to keep the low current items running with the battery "disconnected". However, if someone were to try and start the car with the battery disconnected, the 5 Amp fuse would blow. So... I still have an anti-theft disconnect while the accessories can still be powered up.
bdcvg
They are designed for motorcycle and marine use, hence the cover. They are all over e-bay in various configurations. multiple usb, 12v jack voltmeter etc.
Keoke
OR:Alternatively
A Brown wire under the dash.
Patrick67BJ8
Patrick67BJ8
OR:Alternatively
The brown wire is hot all the time unless the battery switch is off so I ruled that out. I'm thinking of running a wire to the battery as dklawson suggested. I don't want a wire unprotected or looking strange so I thought about a house thermostat type of wire, or similar, that has one or two wires in a vinyl sleeve. The clock doesn't use very much power so I'm not worried about using 16 ga wire. It'll run underneath the chassis and be secured to the battery cable with tie straps.
gonzo
The dual USB charger is sealed with the two prong silicon plug, which, in the closed position, has a cut-out to view the voltmeter values. In the open position the USB ports are white and nicely contrast against black and match lettering of the heater controls. Concealed in the parcel self it works nicely for modern devices. GONZO
Patrick,
I wonder if that could be modified/adapted to just slip into the cigarette lighter...?
Patrick67BJ8
Patrick67BJ8
I found a good website for the wiring diagrams for a Smiths Voltmeter, Ammeter & general Smiths gauges. Not a very good website when it comes to looking up things. I believe installation with the recommended 3 Amp fuses is important and I added a fuse holder in my Clock and Voltmeter gauges. I also used a Label machine and made a label strip/name for the wire as well as the fuse holder, "3 Amp". The first time I hooked up the Voltmeter I connected the hot wire to a terminal and because it was up high under the dash I couldn't see the other spade terminal and I assumed it was grounded by the case since the light worked. Well, I trouble shot it and found the other spade terminal. Works like a charm but I have to say the Voltmeter gauge doesn't make any fast movements...it's slow getting up to the voltage and you'd think it was not working unless you watched it for a while.
  • Gauge, Smiths, Voltmeter.PDF
  • Gauge, Smiths, Ammeter.PDF
  • Gauges, Smiths, Wiring Diagram.PDF
Healey Nut
steveg
I like my Smith's "Battery Condition" voltmeter available reconditioned from sources in GB for around $120, but can understand why one would want one of the above for around $10 -- even if you had to wait a couple of weeks for the slow 747 from China.
Patrick67BJ8
Patrick67BJ8
it sure what that Gauge is. Can you post a photo?
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
R TR2/3/3A Changing to a voltmeter. Triumph 6
P TR6 ammeter vs voltmeter Triumph 9
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
K TR2/3/3A Voltmeter install? Triumph 2
R TR2/3/3A Voltmeter add on reccommendations? Triumph 4
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
B 1500 cc w/ gen...how do i wire a voltmeter to it MG 4
C Smith's Voltmeter from Moss MG 3
Editor_Reid Ammeter vs. Voltmeter Austin Healey 12
EMGEBE Voltmeter installation MG 20
B Land Rover Series 3 Wiring Diagrams Rover / Land Rover 0
J TR2/3/3A Wiring Triumph 11
71TR6 TR2/3/3A A TR3A wiring question Triumph 17
T 1971 Fuse Box and Wiring Triumph 7
tahoe healey Wiring Diagram for Fog Lights Austin Healey 12
P Wanted Wiring scraps Triumph Classifieds 14
olarson TR2/3/3A Horn Replacement Wiring Triumph 7
Sopwith_Camel horn relay wiring Jaguar 3
B Steering Column Wiring/Sealing Austin Healey 1
timsgolf Coil Wiring Austin Healey 20
T Spitfire 67 MK2 Wiring Triumph 12
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
P XJ12 Wiring diagrams Jaguar 1
Scotsman Wiring Diagram for 1966 BJ8 Austin Healey 3
J TR6 TR6 Hayden Pusher Fan Wiring Triumph 2
B TR4/4A Basic Wiring Question Triumph 35
C For Sale Center wiring harness for a 1959 Sprite Spridgets Classified 0
I Lotus Elite wiring diagram Lotus 6
K TR2/3/3A British Wiring alternator conversion kit question. Triumph 3
6 BJ8 Headlamp Wiring Austin Healey 1
S MGB mystery wiring plug MG 2
R TR6 Starter wiring question Triumph 6
R Spitfire Turn signal wiring Spitfire Triumph 5
B TR4/4A High Torque Starter Wiring Triumph 9
N For Sale Wiring harness 64-67 mk lll Spridgets Classified 0
J Wiring Harnesses Issues Spridgets 3
S Wiring Harness Replacement Spridgets 1
R Electric fuel pump wiring Spridgets 4
B TR4/4A Wiring Harness Triumph 6
R Wiring ??'s Spridgets 17
Healey Nut Rear Wiring Routing Austin Healey 2
7 General TR Wiring harnesses Triumph 5
Got_All_4 TR5/TR250 Wiring/Electrical Mystery Worked Perfect Then Not Triumph 5
MGTF1250Dave T-Series TF Windscreen Wiper wiring MG 4
M TR6 Fuse box wiring mystery Triumph 9
Healey Nut Wiring Harness Routing Austin Healey 5
