TR2/3/3A Voltmeter install?
karls59tr
Bronze
I have installed an alternator in the TR3 using the British wiring kit. I came across a voltmeter in a parts bin that looks like it would fit in the dash where the Ammeter is. If I decide to go with the Voltmeter what's the best way to wire it up in terms of what wire goes where? What about the two wires on back of the ammeter?
If I decide to keep the Ammeter and install the voltmeter under below the dash where would the wiring go then?
TR3driver
Great Pumpkin - R.I.P
If you remove the ammeter, you'll need to securely fasten the two wires together, as they carry pretty much all the power for the car. Or, since you aren't using the original control box, you could just move the brown wire over to the headlight switch in place of the original brown/blue wire; then leave the original brown/blue and brown/white wires disconnected at both ends.
The voltmeter will need a good ground, and to be connected into the white circuit somehow. The back of the starter button might be a good place, if you don't already have other wires there.
K TR2/3/3A Wiring a voltmeter gauge to replace the ammeter. Triumph 1
K TR2/3/3A Can anyone confirm that if you replace the ammeter with a voltmeter ( generator removed and alternator added) that you...... Triumph 5
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
R TR2/3/3A Changing to a voltmeter. Triumph 6
Patrick67BJ8 Voltmeter Wiring Diagram Wanter Austin Healey 25
P TR6 ammeter vs voltmeter Triumph 9
K TR2/3/3A Installing a Voltmeter on a TR3? Triumph 10
R TR2/3/3A Voltmeter add on reccommendations? Triumph 4
K TR2/3/3A Adding a Voltmeter to a TR3? Triumph 8
B 1500 cc w/ gen...how do i wire a voltmeter to it MG 4
C Smith's Voltmeter from Moss MG 3
Editor_Reid Ammeter vs. Voltmeter Austin Healey 12
EMGEBE Voltmeter installation MG 20
Celtic 77 MGB Rerouting heather pipe after Weber install. MG 13
angelfj1 TR2/3/3A TR3A Boot Millboard Install Triumph 7
E Heater install Spridgets 2
algot1901 Roof install Other British Cars 16
A Spitfire Install fan Triumph 1
S Install drain cock in radiator. MG 2
Popeye TR4/4A Accelerator shaft install - location of bushing plates? Triumph 2
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
6 Master Cylinder Install Spridgets 5
S MGB Transmission cross member re-install MG 14
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
K TR2/3/3A Brake caliper piston install? Triumph 18
EWD TR6 Top Install Triumph 3
J TR4/4A Seat install, Spring clip Triumph 0
R side light install Spridgets 2
R TR2/3/3A Install new wiring harness in steering column Triumph 16
Joel Lester TR2/3/3A Any advice for new floor install on my TR3? Triumph 9
L TR6 Rear Brakes Shoe Repair and Install Triumph 2
71TR6 TR2/3/3A TR3A Front Sway bar- how to install? Triumph 5
J Tips for quarter elliiptic spring install Spridgets 3
T Pertronix distributor install into Austin Healey 100/6 Austin Healey 12
SherpaPilot TR6 Difficulty with New Seat Diaphragm Install Triumph 6
EWD TR6 Trunion Install Triumph 0
A TR2/3/3A Interior rear panel covering gas tank and rear seat bottom install. Triumph 7
66healey BJ8 shifter spring install Austin Healey 2
K TR2/3/3A Steering box install again...the collar with the pinch bolt? Triumph 9
GeorgeC Intake / exhaust manifold gasket install goop? Spridgets 2
C How to install Stone Guards on driving lights? Austin Healey 7
F Heater valve/tap gasket- Install dry? Austin Healey 10
Csarneson BN4 Cam Gear Install Austin Healey 3
Rut 5 speed install Spridgets 14
R More Shroud to Scuttle install Austin Healey 4
R Dash Install questions Austin Healey 31
S TR2/3/3A how to install a gas tank in an early tr3 Triumph 8
P BJ7 Carpet Install Questions Austin Healey 29
J TR2/3/3A Trunnion Install Triumph 3
