Hey there Guest! If you enjoy BCF and find our forum a useful resource, if you appreciate not having ads pop up all over the place and you want to ensure we can stay online - Please consider supporting with an "optional" low-cost annual subscription.
The easiest way would be to run a wire from the clock to the "always hot" side of the cutoff switch.
On the Mini I have a battery cable disconnect. I have a 5 Amp fuse wired in parallel to the disconnect. That allows me to keep the low current items running with the battery "disconnected". However, if someone were to try and start the car with the battery disconnected, the 5 Amp fuse would blow. So... I still have an anti-theft disconnect while the accessories can still be powered up.
For clarification: could I have a wire coming from the Gauge to the positive terminal of the battery and a light gauge wire with fuse to the ground? The gauge has a wire to ground already. Car is Negative ground.
thanks
thanks
No, you should have the fuse in the positive wire to the gauge, and it should be near the battery. That way, if the positive wire shorts out on the way to the gauge, the fuse will blow instead of the wire burning up.
Okay, no problem since I was considering doing that. What about the negative wire...install a small gauge wire from the Neg on battery to the Ground by the cut-off switch?
I tried a 5 Amp and it worked. I tested it by turning off the battery and noted clock still working then I turned on the headlights and the fuse blew, which it should have.
A friendly reminder - be careful what links you click on here. If a link is posted by someone you don't know, or the URL looks fishy, DON'T CLICK. Spammers sometimes post links that lead to sites that can infect your computer, so be mindful what you click.
(Click X in the upper-right to dismiss this notice)
