Frank C.
I have developed some minor leaks in the side of my valve cover. They are associated with some of the spot-welds that hold on a metal plate on the inside of the cover. I have two of them and they are literally pin-holes that dip out when I take the car for a longer run.
The questions are, has anyone experienced this and, if so, what is the best fix? I am thinking about sanding the outside of the cover and putting a thin layer of high temperature epoxy on. Then sand and repaint.
As always, I will appreciate any suggestions ...
Frank
Frank
