Question about 100-4 valve cover
bighealeysource
Bronze
Hey all,
Just bought a used 100-4 "original" steel valve cover. Question I have is the oil cap a pop on style like the 6 cylinder cars or a screw on style which this cover requires ? I had a BN1 but do not recall it having threads on the oil cap mount, but like the 6 cyl cars. I have the polished aluminum style replacement cover on my 100M.
Thanks,
Mike
bighealeysource
bighealeysource
Bronze
Thanks guys, that's what I figured after looking at a few pics of 100-4's and trying to focus on the cap. Now just have to find someone that sells the correct cap and watch ebay !
healeynut Sticky Valve/guide/ spring question 100 Austin Healey 4
longbridgehealey 100-6 BN4 horn question Austin Healey 2
B Austin Healey 100/6 vin plate and serial number question Austin Healey 3
B Question about Oil Filter Orientation on Early 100-6 Austin Healey 4
C Quick question before I begin my first transmission fluid change on my 1959 100-6 Austin Healey 9
A 100 engine main bearing cap nut question Austin Healey 0
cmc140 Austin-Healey 100 front splash pan / splash shield question. Austin Healey 8
HealeyDave 100 door hinge question Austin Healey 4
H disk brakes on 100-6 question Austin Healey 14
D Rag Top frame for 100-6 question Austin Healey 8
B 100-6 serial number Question Austin Healey 4
Y 100-6 shroud opening for grille question Austin Healey 3
bighealeysource steering box and distributor question on 100-4 BN1 Austin Healey 7
kurts100 Question on Pertronix for my positive gnd. 100-4 Austin Healey 4
curtis 100 overdrive question Austin Healey 5
Thomas591 Stupid question on 100 BN2 Axle Austin Healey 3
Dave Richards 100-4 Vin# Question? Austin Healey 12
L 59 100-6 Wiring Question Austin Healey 14
J 100-6 Frame question Austin Healey 6
V 100-4 rocker assembly question.... Austin Healey 2
DonC1948 TR6 A "CLASSIC" question. Triumph 6
K TR2/3/3A Cylinder Head Bolt question.... Triumph 3
D TR2/3/3A TR2 Flying Mile question Triumph 11
M New Member with an HD8 Carb Question Austin Healey 1
Gliderman8 TR6 New shocks (damper) question Triumph 4
D TR2/3/3A Windshield assembly question Triumph 6
T MGB Quick question about something that don't really matter just want to know. MG 9
CARSINC Throttle linkage question Spridgets 1
S TR6 Steering question you will not hear every day Triumph 1
JPSmit Hypothetical Question of sorts - wheel bolts Restoration & Tools 12
E TR6 TR6 flip-up bonnet question Triumph 4
D TR2/3/3A headlight question Triumph 8
D A distributer question on the 1275 engine. Spridgets 7
P TR2/3/3A TR2 Headlight Trim Question: Triumph 8
SherpaPilot TR6 Ignition Switch Question Triumph 13
SherpaPilot TR6 Engine Mounting Question Triumph 3
5 TR2/3/3A TR3 fender patch panel question Triumph 10
WHT Oil Sump Question For Dougie Austin Healey 0
LD-Ordie Series II gear lube question Rover / Land Rover 3
T TR2/3/3A TR3A Windshield Question Triumph 4
