been a couple of good days now for trying some test drives. unfortunately, yesterday, i spent on replacing the alternator which quit working. but all back together now. also did a couple of other projects i was needing to clean up.
so today i figured i would take a couple of test runs. weather was a little warmer and i had the afternoon free. So i get in the car and take a run up to the gas station. just a couple of miles with a couple of stop lights. by the time i get there the gauge is at 190. shut it off to put in gas and when i start it up, it drops to 180. i took off down the highway and soon it is back up to 190. the next light i am sitting it, it goes up to maybe 200 or so but cools back down to 190 after getting moving again. in all i rode about 12 miles or so. i have been having an issue with a sticking throttle and it was being a pain so i turned around and headed home. again mostly highway driving. got home and it was still at 190, maybe to the high side. pull it in the shop and shut it off.
the engine is off and i am watching the gauge as it climbs. the gauge goes up to i'll say 220 or so. at that point i hear water blow out the overflow and in to my overflow bottle. did not think any more about that because i knew i had added some extra coolant to bring the level up to the neck. so not surprising.
at this point i am figuring ok, it did not go above 190 while driving so i just need to get used to that. but this is where it gets funny. i am fiddling with the throttle linkage and trying some things. the car is cooling down some. after some adjustments to the linkage i figure i will go back out and test it. by now the the guage is about down to 190. i fire it up and go for another 15 mile ride. the gauge started out going right down to about 180. it never went up from there. thru the whole ride and even sitting at stop signs. it may have once gotten to what i would call 185? while i was waiting on some traffic. but went right back to 180.
in fact i went on a number of runs, maybe a few miles each time, making adjustments to the linkage. never did it run hotter than 180. when i would shut the car down after a run, even the 15 mile one, the gauge never went above the 212 mark.
So maybe it just needed that burp... it will be interesting to me to see if it acts the same way on a new day or will it now stay at the 180 mark when i run it. i am not going to add any fluid to it or even pull the raditator cap just to see.
below is a picture of the of the overflow bottle after the burp. the tape i had put on there to show the starting level. i wanted to see if it would put out any fluid while i was driving. it did not. none until the big burp. i mean by "the burp" that is what it sounded like. not only fluid blowing out but it sounded like air with it. of course that could have just been air in the line or the fact that the bottle has a smaller vent hole that the line coming in.
so needless to say i am pretty happy it ran at 180 for the rest of the day. if it started like that i would never have started this thread.
i do appreciate all the help and comments you all offer. i know i probably seem to worry too much about this but this is like a couple with their first born. you just worry about everything that does not look right at first glance. partly because you have no history to compare it to. overheating the engine could be a big issue and a very exspensive one. So i am a little extra cautious. i do plan to grab a meat thermometer and give that a check just out of curiosty, as soon as i get the chance.
for now we shall see what the next road test brings.
