TR6 TR6 Front Suspension Resto Project Part One
LoneRanger
Member
Does anyone have a copy of the 1969 Triumph TR6 Front Suspension Restoration Project Part One-Disassembly by Dale (Tinster)?? I have found parts II & III, but having difficulty with Part I. My email is joseph_mannino@yahoo.com
Brosky
The best guy to ask would be Dale and he'll probably be around soon after he finishes driving all over the island or catching tarpons this morning.
Send him a PM in case he misses this thread, which is doubtful, but possible.
Mickey Richaud
And welcome to the party!
Mickey
L
LoneRanger
Member
I plan on replacing all bushings, Shocks, Springs, Tie Rod Ends, Trunnions, Anti-Sway Links, Upper Ball Joints, Fulcrum pins. Am I missing anything critical?
3798j
Bronze
I failed to realize how important it is to renew the inner tie rod ends. That was a disappointing mistake I had to correct. Also,if the budget allows, put Konis on.
L
LoneRanger
Member
Thanks Jay, some nice images and quite a collection of vehicles. Have to draw some lines with the budget, went with some basics.
T
Tinster
Joe,
I'll be happy to walk you thru the process if you post progress photos
so other members may learn. Unless you already know your trunnions and fulcrum
pins are messed up, I would NOT purchase them in advance. Steering rack boots
are inexpensive and you should probably buy a pair. I purchased all new fasteners;
at a minimum you will need all new locknuts and new lock washers.
Do one side of the car at a time. The second side will be completed much faster.
Could you pull off a front wheel and post a photo of your existing front suspension?
Have ALL your parts in-hand before you start the project.
my e-mail is: crcroof@onelinkpr.net
glad to pay back some of the help I received.
best regards,
dale
tdskip
What vendors and composition bushings and springs are you going to be using. Please be aware that there is healthy debate about the impact of new springs on our cars. More specifically, some vendors springs make the cars sit very high and other too low. Better to find out now - ask me how I know....
L
LoneRanger
Member
Bought items from TRF. Currently at work, so I can't get more specific than that right now, will post later. Thanks.
L
LoneRanger
Member
Dale, Not sure about posting progress photo's as I go, the setting may not be condusive to doing that. I'll post what I can, but it may not be close to real time. At work right now, will post later. Thanks for you help.
G TR2/3/3A TR6 Front Suspension A-Arms on a TR3A? Triumph 5
R TR6 Front TR6 Suspension Question... Triumph 7
I TR6 This can't be good. TR6 front suspension rebuild Triumph 25
I TR6 Tinster's TR6 front suspension restoration part 1? Triumph 7
I TR6 TR6 front suspension rebuild suggestions Triumph 19
T TR6 Tr6 front suspension ? & downside of Cali cars Triumph 1
T TR6 TR6 front suspension re-bushing question Triumph 18
E TR6 TR6 Front Suspension... Is there a trick? Triumph 8
John_Mc TR6 Front Suspension Rebuild TR6 Triumph 16
G TR6 TR6 front suspension in a TR3 Triumph 3
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
C TR4/4A Advice for grafting TR6 frame front to TR4A frame rear Triumph 15
M Wanted WTB Late model TR6 Front Brake Caliper Brackets Triumph Classifieds 0
R Wanted 75/76 TR6 front licence holder Triumph Classifieds 1
J Wanted TR6 Chrome Front License Plate Holder Triumph Classifieds 0
A TR6 '73 tr6 passenger front brake dragging Triumph 2
M TR6 TR6 Gas Leak From Front Carb Triumph 5
D TR6 1976 TR6 Front Brakes & Shocks Triumph 3
hondo402000 TR6 TR6 Heavy duty front Stub axles Triumph 12
K TR6 TR6 front end Triumph 2
W TR6 TR6 front wheels Triumph 7
hondo402000 TR6 TR6 front end alignment and wheel balancing Triumph 4
Coyote1 TR6 74 TR6 Front Turn Signal Alternative Triumph 9
davidk TR6 Information for front crank seal - TR6 Triumph 11
hondo402000 TR6 TR6 Front Wiring harness on its way Triumph 0
B TR6 TR6 Front Oil Seal Sleeve Triumph 3
charlie74 TR6 TR6 front bearing cap Triumph 4
T TR6 TR6 front wheel bearing ? Triumph 5
N TR6 How to check TR6 front wheel bearings Triumph 1
hondo402000 TR6 TR6 Lower front valance section replacement Triumph 2
I TR6 TR6 - how to pack front wheel bearings? Triumph 8
R TR6 Late TR6 Front Fender Removal Triumph 5
I TR6 TR6 front shock help Triumph 2
T TR6 Question on TR6 lower front inner wishbone bracket Triumph 1
hondo402000 TR6 TR6 rebuilt the Front Calipers, second time Triumph 2
hondo402000 TR6 Front Brake issues TR6 Triumph 2
A TR6 TR6 Front lower wishbone mount [rear] broken Triumph 1
N TR6 TR6 Front Spring Height?? Triumph 3
T TR6 tr6 front wheel bearings Triumph 15
jjbunn TR6 TR6 Front Hood Seal Triumph 6
zekjet TR6 Longer Front Wheel Studs for a TR6? Triumph 3
N TR6 Clip wires on front brakes for TR6 Triumph 9
SCguy TR6 TR6 front sway bar on a TR4 Triumph 1
T TR6 Decided to repair TR6 front valance rather than... Triumph 4
C TR6 Proper way to adjust front hubs, TR6? Triumph 13
hondo402000 TR6 TR6 front glass question Triumph 4
2wrench TR6 Pictures of TR6 dash refinished front + back Triumph 22
A TR6 Motor mount position--front/back?? TR6 Triumph 2
E TR6 TR6 front engine seal leak Triumph 11
R TR6 Lowering TR6 front end Triumph 15
