TR6 Longer Front Wheel Studs for a TR6?
zekjet
I'm trying to find longer 7/16" front wheel studs for my TR6. Just added new alloy wheels "Konig Rewinds" and have made the clearance adjustments with the upper A arm and turned around the balljoint bolts, but in reverse at full lock, the rim will make contact with the ball joint bolt, so I am trying to add a hub spacer, which leaves my 1.5 inch studs a little to short for the lug nuts. I've called the big 3 and no luck. Any suggestions would be greatly appreciated.
zekjet
zekjet
Thanks for the reply! ARP has pretty close to what I need, I'm concered about the knurl diameter, the stock stud is approx. .510 and they offer a diamter's @.48 and .56 on up. I suppose I could ream the stud holes on the front hub for a proper seat.
Bugeye58
When I change Sprite hubs to the 100-7701, 7/16" studs, I have to open the holes up to .453" to accept the larger (.486")knurl.
Incidentally, those are GM wheel studs, so are also available at parts stores, in the stock material.
Jeff
steveg Nisonger no longer in service business Austin Healey 12
R J-H no longer needs a push! Other British Cars 6
K TR2/3/3A Longer wheel studs? Triumph 5
TomChar General TR LBC's no longer in their prime... Triumph 14
cmacmillan TR6 metering needle - no longer in a relationship with adjustment screw... Triumph 9
J TR2/3/3A Need a longer choke cable, IE: all the way to the pull knob Triumph 1
DrEntropy Can't put it off any longer. MG 10
K TR2/3/3A Source for TR3 wheel studs that are 1" longer? Triumph 8
Ed_K Castrol Syntec 20w-50 no longer available ? Austin Healey 21
K TR4/4A Longer TR4A intake manifold on a 3...... Triumph 5
T longer wheel studs need help finding Triumph 11
B I'm no longer safe! Spridgets 23
S This won't last much longer! Jaguar 4
AUSMHLY Longer grease fittings Austin Healey 8
milemarker60 Looking for longer studs? Here's my research Triumph 2
A Its starrting to stay light out a little longer. Spridgets 4
catfood TVR No longer under British ownership... Other British Cars 9
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
71TR6 TR2/3/3A TR3A Front Bumper Mount Triumph 11
1 TR2/3/3A Rimmer Brothers Replacement Front Wing Quality? Triumph 8
Carlbanan56 MGB Front hub MG 4
J MGB Front Wheel Bearings. Re-grease or replace? MG 19
scottkilpatrick TR4/4A Front Brakes - Basics for Pads Triumph 11
C MGB-GT MGB-GT Front Ride Height MG 0
C MGB-GT Front Ride Height MG 0
J For Sale Bilstein Front Shocks for Jaguar E-Type 727-498-6493 Jaguar Classifieds 0
J TR2/3/3A Mystery knocking sounds at front wheel Triumph 11
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
K TR2/3/3A Front brake hub removal to access Vertical Link bolts(screws) Attached pictures. Triumph 1
K TR2/3/3A How to remove the front brake hub from the brake disc? Triumph 11
AUSMHLY Front Wheel Spin Drag Austin Healey 6
mctriumph TR2/3/3A Front Suspension upgrades for the 59 Triumph 10
CARSINC For Sale Sprite Front Wire Wheel Hubs Spridgets Classified 0
bighealeysource Front Brake Adjusters Austin Healey 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
TR3Acustodian TR2/3/3A Replacing "H" front badge Triumph 11
G Rebuilding Front Seats Austin Healey 4
drooartz MGB Front suspension rebuild is next MG 57
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
H TR4/4A Advise asked for front repair Triumph 1
A BN7 Front Hub Stud Nuts Austin Healey 5
P 100/6 Front Wheel Alignment Austin Healey 10
Prof. T Wanted 1974 - TR 6 Front Chrome License Plate Holder Triumph Classifieds 1
