To my mind, the main advantage of the HS6 carbs is the elimination of the jet and float bowl seals. With the H6 carbs on my daily driver, it seems I never go more than a year or two without having to change those dang seals.
I've also been told that they flow better than the H6 carbs, but that the difference isn't very much.
Supposedly (again just what I've been told), the curved tube manifold actually flows less up around redline, but improves flow in the midrange. IOW it trades off peak power for more mid-range power. If your cam has moved the usable power band up by very much, the late manifold may be hurting you overall.
But the stock TR3 intake manifold may not fit with some headers.
