TR6 Question on TR6 lower front inner wishbone bracket
PeterK
Good question. Even on my 4A, there are two set of holes and I wondered why as well. There is a change from the 4A to the 6 that adds two mounting studs for strength and I have done this mod to my 4A. But I don't know why two set on each side either. So make that two inquiring minds.
Also where/what commercial was it that introduced "inquiring minds want to know?" How 'bout "Ancient Chinese secret?" others?
CinneaghTR TR6 TR6 Lower Wishbone Arm Question Triumph 3
E TR6 TR6 flip-up bonnet question Triumph 4
J TR6 73 TR6 Temp Gauge Wiring Question Triumph 6
B TR6 TR6 1976 Clutch Choice Question Triumph 3
J TR6 TR6 Differential Rebuild question Triumph 6
P TR6 1970 TR6 Timing Question Triumph 2
J TR6 TR6 Brake Question Triumph 1
P TR6 TR6 fuel pump question - glass bowl pump correct? Triumph 8
SherpaPilot TR6 Just Another TR6 Column Question Triumph 4
Gerry M TR6 TR6 Steel Wheel Question Triumph 3
M_Pied_Lourd TR2/3/3A TR6 Transmission Swap Clutch Slave Question Triumph 3
J TR6 '73 TR6, Wiring Question. Original Owner Triumph 5
TR3TR6 TR6 Question about a TR6 J overdrive Triumph 12
sundown TR6 1973 TR6 flasher question Triumph 6
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
toysrrus TR6 TR6 & GT6 Flywheel, Clutch question: Triumph 4
bigbadbluetr6 TR6 TR6 carb question and running rough Triumph 13
S TR6 Quick TR6 alternator question Triumph 6
TR6BobNF TR6 TR6 Dashboard Hinge Question Triumph 3
W TR6 Question on Steering Wheel Puller for 1974 TR6 Triumph 10
I TR6 75 TR6 vacuum hose question Triumph 2
B TR6 1972 tr6 orignality question Triumph 3
W TR6 carb question tr6 Triumph 1
M TR6 TR6 Master Cylinder Rebuild Question Triumph 10
I TR6 TR6 paint question Triumph 8
Coyote1 TR6 TR6 Header Rail Question Triumph 4
gbtr6 TR6 Question on TR6 trunnions and inner tie rod ends Triumph 6
Pete_Chadwell TR6 TR6 Rear Hub question, plus gearbox vibe Triumph 8
B TR6 TR6 Boot Cover Question Triumph 4
G TR6 TR6 caliper/hose fitment question [VB] Triumph 3
mgedit TR6 Transmission Question TR6 in TR4 ... will it work? Triumph 4
B TR6 1972 TR6 Differential Rebuild Question Triumph 3
hondo402000 TR6 TR6 Amp Meter question Electrical guru needed Triumph 4
S TR6 TR6 Bumper question ?????? Triumph 3
hondo402000 TR6 Another TR6 wiring question Triumph 5
hondo402000 TR6 TR6 Wiring/amp gauge question Triumph 8
G TR6 TR6 caliper question [Toyota 4 piston?] Triumph 2
SherpaPilot TR6 TR6 Rear Axle Bearing Question Triumph 10
hondo402000 TR6 TR6 Clutch question Triumph 5
glemon TR6 obscure tr250 tr6 seat rail question Triumph 4
W TR6 TR6 Differential Question. Triumph 6
T TR6 Question on TR6 throw out assembly Triumph 9
W TR6 TR6 Timing chain oil seal question Triumph 3
R TR6 Front TR6 Suspension Question... Triumph 7
wangdango TR6 TR6 solex question? Triumph 16
B TR6 This question is for the TR6 restorers...... Triumph 7
Z TR6 Question about rebuilt TR6 calipers Triumph 3
T TR6 Fuel tank question - TR4a & TR6 truly identical? Triumph 3
