TR4/4A TR4 Suspension Safety Issue?
KVH
I'm having a little difficulty believing that the lower fulcrum bracket of the TR4 suspension, the one that holds the wishbone arms, is held only by one single bolt. I know the TR6s went to two (or think they did), but it seems to me that one lose bolt on a TR4 could be mean major problems. Does this bother anyone else?
PeterK
It's common to either add the second bolt or obtain TR6 lower mounts. Most later frames already have the second holes drilled.
Tabcon
I noticed the same exact thing yesterday when I was disassembling the front end.
Mine were on very tightly though and they are nyloc bolts. From what I understand, most of the force exerted on the front suspension is on the upper A arm where they have castle nuts with cotters installed. Good idea on the second bolt though, I'm going to do that when it all goes back together.
TR4nut
If I understand this thread correctly, I think you are talking about the 4A suspension, which is weak with one bolt holding the lower brackets. The TR4 suspension is different (its the same as the TR3).
Gerald_Gordon TR4/4A Preferred front springs and suspension bushings for mild driving in a TR4 Triumph 3
S TR4/4A TR4 front and rear suspension Triumph 8
TR4v8 TR4/4A tr4 front suspension question Triumph 2
J TR4/4A TR4 rear suspension Triumph 8
S TR4/4A TR4 front suspension shimmy and shake Triumph 8
T TR4/4A Early TR4 Rear Suspension & Tube Shock Conversion Triumph 13
Kirk_Fisher TR4/4A TR4 handling/suspension upgrades Triumph 19
T TR4/4A Early TR4 Rear Suspension Triumph 22
R TR4/4A TR4 IRS coil over rear suspension Triumph 3
Tabcon TR4/4A TR4 Rear Suspension Upgrades Triumph 15
B TR4/4A TR4 Suspension Rebuild Triumph 21
K TR4/4A Paging TR4 nut....re front suspension Triumph 2
M TR4/4A TR4 Front Suspension Rebuild Triumph 6
M TR4/4A TR4 Suspension Triumph 1
T TR4/4A Early TR4 - Front Suspension Trunnions Triumph 7
SCguy TR4/4A TR4 front suspension question Triumph 8
TR4nut TR4/4A TR4 suspension rebuild Latest - help need a part! Triumph 0
TR4nut TR4/4A TR4 front suspension rebuild advice Triumph 13
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
E TR4/4A What Flare to put on a TR4 Brake Line Triumph 2
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level Opinion - Differential Gasket Replacement 62 TR4 Triumph 10
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
KVH General Tech Jacking Up The Rear of TR4 Triumph 5
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
KVH General Tech Issues with Distributor--TR4 Triumph 13
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
