Hi Randy,
I agree with the points about using urethane. They are much more durable than rubber and will help make the handling more precise.
Downsides to urethane include that they sometimes squeek, which would be addressed with Tom's suggestion. There is special grease for use with urethane bushings. It can just be wiped on, or use a zerk as Tom suggests so that it can be greased again later.
Another "problem" with urethane is that it will make any other faults in the suspension more obvious. Things like bent arms or misaligned geometry will be more obvious. Of course, using rubber just masks the problem, it's still there.
A third consideration, expect a little more road noise with urethane bushings. Exactly how much depends upon the hardness of the particular bushings you use.
Speaking of which, it's not been mentionted that urethane is available in a variety of hardness or durometer ratings. Some can be close to the same as the original rubber, most are a little firmer, some are a lot firmer. It might pay to shop around. I think Superflex is one brand that comes in different durometer, but I'm not that knowledgeable about TR urethane options. Seems most U.S. vendors just offer "rubber or urethane" kits with no further info about the urethane. I see some of the British vendors offer choices of TR kits in various urethane hardness. I've got a set of softer "offroad" urethane bushings for my Land Rover, not yet installed. Rover vendors do tend to offer choices.
Rather than TR-specific kits, urethane bushings can be bought locally in "standardized" sizes. All the applications on TRs can actually be found amoung standardized sizes, except for the rather odd-shaped mounting bushings for OEM sway bars. One reason to buy this way, is that some local tuning shops in my area are now offering a selection of hardnesses, might be in your area too.
You asked about nylatron and I'll be interested to hear Doug's response. In general, nylatron is harsher than urethane and most would consider it a "race only" option. In fact, there are nylatron bushings already being used on the lower/inner a-arm joints of TRs. Those are original to the cars. With minor modifications, these could be used at the upper/inner joints, too. But, I'm sure that would make the ride harsher. Nylatron will be considerably noisier, too.
I've now got urethane installed on my TR4: front upper suspension, upper and lower front shock mounts, plus both the mountings and end links of the front sway bar. But, I can't really say how I like it yet, since the car isn't back on the road yet. I did use rubber on one end of the sway bar end links, to allow about half the normal movement before the bar becomes effective that a "stock" sway bar setup would have. I'll try it that way and can always swap to full urethane or full rubber, to tune the sway bar action a little.
One last thing I think I'll change is to eliminate the rubber bushings at the TR's rear shock links. I plan to replace those stock links with custom rod-end type (aka rose joints in England). This makes the shock more effective, with no slop in the end link, but tends to transmit more road noise, too.
In fact, rod-ends can also be used on the front suspension and/or sway bar. However, this is definitely a full race type suspension and would be very harsh and noisier. (Note: rod-ends you find might in your local hardware store probably are not up to the task... racing suppiers such as Pegasus, Summit, Jegs and Racer Parts Wholesale offer stronger, often Teflon-lined ends that are appropriate for suspension use, but are pricey.)
To summarize:
- rubber... mushier feel, don't last long, but forgiving of some suspension misalignment, softer riding and quieter.
- urethane... more of a sports car feel, a little harsher and noisier, possibly will squeek, but are available in different hardnesses.
- nylatron... more of a race car feel, harsh and noisy, but even more precise handling than urethane.
- rod ends... a full race setup, very precise, but very harsh and noisy, expensive, will require custom installation, more prone to wear and will need more frequent service.
One thing I do get a kick out of is the urethane "upgrade" spring bushings being offered from some vendors. These are the pads that go at the top and bottom of the coil spring, primary purpose to prevent direct metal-to-metal contact and noise. Well, the 40 year old rubber ones on my TR had hardened to urethane-like consistency, so I happily reused them!
