If you are running 14" wheels and the car sits that low and has so little clearance, maybe someone has already removed the aluminum spacers from a set of the shorter springs. That was a common "lowering trick" in the old days, but really doesn't pre-load the shorter springs enough. The aluminum spacers are 1.25" thick.
I had a set of 14" mag wheels on my TR4 originally, but they had too little offset. I don't know what they were off of. Wider track made the car really stick in the corners, but I never could get adequate clearance with those wheels, even though they were smaller diameter. I even tried a 195/60 or 65 tire, but they still kissed the fender on hard cornering.
About 5 years ago I finally ended up getting a set of 15" x 5.5" wheels with the correct offset, now clad with 195/60 Goodyear tires. No clearance problems and room to lower the car more, if I choose. I probably will because there is presently 2.5" clearance between the tire and the edge of the fender, which looks a little much.
Moss, Victoria British and others sell the heavy duty springs. Shop around. Moss is about the most expensive place to buy most parts. Try TRF, British Frame & Engine, and some of the smaller shops.
If you need a set of the aluminum spacers, you'll probably have to track down some used ones. Triumphs Only might have them, or Ted Schumacher at TSI. Or, post a request here and see if anyone has a spare set.
Be a little wary of using HD springs up front with standard leaf springs in the rear. I'm not sure how they will balance. Might be okay without a front sway bar, but might be too stiff with one. I guess the only way to be sure is to try them and see if it works okay. I've got HD both front and rear, plus a .75" front sway bar, Konis up front and HD lever shocks at the rear. It's a damned stiff setup! You can hardly bounce the car at all. I'm working now to lower the rear about 1.5" with spacers between the springs and the axles (4" between the tire 60-series tire and edge of fender). I may end up going to a softer setup eventually, if I can't stand the ride! It should corner like it's on rails, though!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
