TR4/4A TR4 overdrive relay position
Adrio
Now that I have the mechanical and electrical part of my "new" overdrive worked out for my TR4A, I have a question. Where is the overdrive relay suppose to be located. I am looking in "obvious" places trying to find holes that match the relay mounting holes but no luck.
Alan_Myers
Hi Adrio,
The relay mounts on the cockpit side of the firewall, just above and to the right of the gearbox cover. It's sort of, but not exactly on the internal side opposite the starter solenoid mounting point. You should find one or two short, unused studs there. I'm guessing without looking that they are #8 or #10 NF threaded.
The wiring comes out through an approx. 1/2" diameter hole in the gearbox cover, near the front and slightly off center to the right. I imagine there was a rubber grommet in that hole to protect the wiring and that it just sort of snakes out from under the gearbox's carpet cover up near the firewall.
Have fun!
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
A
Adrio
Thanks Alan. I will look for the spot. My gear box cover does not have the hole in it (yet) as it is a new poly one I got.
I am torn between making a wire loom for this and installing it with a temporary switch while I wait to find a used (or buy new) and get delivered switch or just waiting and doing it once when I have all the parts. I only have two more months of driving this summer so I am leaning towards the temporary option as it gets the car back on the road sooner.
Alan_Myers
Hi again Adrio,
I bought the wiring harness that goes from gearbox/OD to the relay. It's not expensive and I wanted the properly color-coded wires. On the other hand, it wouldn't be hard to make one up if you had the bullet connectors. I added a couple clamps to secure the wiring on top of the gearbox.
I think the steering column switch wiring is already present as a part of the main harness. However, I really can't confirm this since I'm using a custom switch and wiring (in the shift knob).
Alan Myers
San Jose, Calif.
'62 TR4 CT17602L
A TR4/4A TR4 Overdrive Solenoid Triumph 19
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
J TR4/4A TR4 A Type Overdrive Part mixup Triumph 4
T TR2/3/3A Will Spitfire D-type overdrive work in TR3 with TR4 transmission? Triumph 3
R TR4/4A Changing from 4 speed to Overdrive on a TR4 Triumph 18
O TR2/3/3A TR4 overdrive in TR3 Triumph 4
jfarris TR2/3/3A Identifying a TR4 A Overdrive Triumph 5
KVH TR4/4A TR4 Overdrive Switches--Top Cover Triumph 8
TR3TR6 TR4/4A TR4 Transmission Question [non overdrive] Triumph 11
J TR4/4A TR4 Trans/overdrive repair shop in Upstate NY? Triumph 7
thechileman TR4/4A Overdrive Solenoid issue TR4 Triumph 8
T TR4/4A TR4 Overdrive Conversion Triumph 8
Mark Jones TR4/4A Anyone looking for an overdrive for a TR3 or TR4 Triumph 4
A TR4/4A TR4 overdrive built from two other boxes - Latest Triumph 0
S TR4/4A Adding overdrive to tr4 Triumph 7
S TR4/4A TR4 overdrive slow to engage Triumph 5
R TR4/4A 1963 TR4 soft hood cover with attached plastic stiffeners Triumph 2
T TR4/4A TR4 seat buffer problem Triumph 5
KVH TR4/4A TR4 Movie Showcase Triumph 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
scottkilpatrick TR4/4A Send Unit Issues - 62 TR4 Triumph 4
EvansClassicCars For Sale 1966 TR4 Triumph Classifieds 0
S TR4/4A TR4-Stromberg throttle shaft play Triumph 3
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 - Part 2 Triumph 8
scottkilpatrick TR4/4A Difficulty Level with specific maintenance TR4 Triumph 10
mctriumph TR4/4A earliest Tr4 ?? Triumph 0
D TR4/4A TR4 inner ball joints Triumph 8
jfarris For Sale TR4 Fuel Gauge with 2 Transmitters Triumph Classifieds 0
mctriumph For Sale hood for early Tr4 Triumph Classifieds 0
Rod-H TR4/4A TR4 Body Number Plate Supplier Triumph 6
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
KVH General Tech Heater and Vent Control Cables--TR2 thru TR4, and more . . . Triumph 3
Tim Tucker TR4/4A Konig 16x7 wheels and leaf spring clearance for TR4 Triumph 5
MTr4 TR4/4A In search of a 1962 TR4 Triumph 2
A For Sale 1963 TR4 for sale Triumph Classifieds 0
Cokerair TR4/4A Searching for "How To" instructions for TR4 Tonneau Triumph 5
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
mctriumph For Sale Tr4 Short bubble Bonnet Triumph Classifieds 2
K TR4/4A TR4 no start Triumph 26
L For Sale TR6 1976 (restorable project) and TR4 1966 for parts Triumph Classifieds 4
G TR4/4A TR4 Lacks Spark! Triumph 22
