TR2/3/3A TR3 Upper Wishbone Fulcrum Pins? Too Worn?
PatGalvin
Hello All.
I'm cleaning 50 years of grime off the suspension parts for my 59 TR3A. I purchased TRF Magic Kit to rebuild the suspension. Using poly bushings where upper wishbones pivot on upper fulcrum pin.
I cleaned up and powder coated my upper fulcrum assembly but the actual pins are pretty corroded. They are not really worn - just corroded. See photo.
https://s987.photobucket.com/albums/ae352/PatGalvin_bucket/Upper%20Fulcrum/
https://i987.photobucket.com/albums/ae352/PatGalvin_bucket/Upper%20Fulcrum/IMG_7723Large.jpg
So, do I need to replace these, or just clean them up and try and create a smooth surface for the poly bushing. I assume the poly bushings must pivot on these pins, so if I clean these up and grease them during assembly, do you think it will be OK? Right now, the new poly bushes fit pretty tight. I think I could take some wet/dry sandpaper and clean up these pins.
Any advise from you guys? Clean up the fulcrum assemblies or replace with new?
Thanks again
Pat
PeterK
Pat,
They look fine from the photo. Just use a strip of emery paper and polish the rust off.
-Pete
TR3driver
Great Pumpkin - R.I.P
Me too.
TR4
One thing to remember is to loosely tighten the nuts on any moving part of the suspension and apply the proper torque after the car has been lowered and is resting on the wheels.
TR3driver
Not really necessary, IMO, with the urethane bushings. In fact, I prefer to properly tighten all the pivots before installing the springs, to check for free motion.
The stock rubber bushings are the ones that need to be tightened with the suspension in roughly the center of travel, because the bushings distort as the suspension moves, rather than turning as the urethane (or nylon/Nylatron) bushings do.
T TR2/3/3A Has anyone put late TR4/4A upper A-arms and ball joints on TR3? Triumph 3
B TR4/4A Help on upper radiator support rod parts - what is required on TR3 compared to TR4? Triumph 5
B TR2/3/3A Adjustable Upper Fulcrum for TR3 Triumph 9
T TR2/3/3A TR3 upper A arm bushings Triumph 6
mcguijo TR2/3/3A upper fulcrum pin TR3 suspension Triumph 5
S TR2/3/3A tr3 upper fulcrum control arm Triumph 1
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
