Tinkerman
The connection to water pump pipe, assembly, item AU22, Stanpart #201947, plate AU opposite pg 146, in the Stanparts catalog mounts to what, besides the water pump? It has a tab about in the middle that hangs down close to the coil mounting bracket. Figured that would be where it should go. The hole in the tab is about an inch to the rear of the rear most coil bracket mounting hole. Can't go forward because it hits the interior of the housing. The one I bought, a SS unit from TRF is an exact copy of the original. So whats up?
Any and all ideas greatly appreciated.
Thanks, Tinkerman
Thanks, Tinkerman
