TR2/3/3A TR3 front suspension report
prb51
Just finished a 20 mile shake out after rebuilding the front end.
I rebuilt with the TRF kit and poly bushings thruout.
No squeeks at all.
The left side upper poly bushes were mounted 'dry' and the right side with anti seize (an afterthought after reading a post here)...neither side squeek, no dif.
The original rubber bushes squeeked some as the PO had the upper inners too tight and the lower outers too loose (it still worked well though).
I didn't notice any harshness, actually the opposite with less jolting over bumps, with the TRF provided poly.
I replaced all of the steering ball joints and the idler assembly.
Steering seemed tighter (harder steering) with the wheels in the air but is actually easier under way.
I purchased the new idler assembly from a popular internet auction medium (many for sale usually) and it worked out ok after I took the time to smooth the action of the idler arm in it's housing (initially out of the box stiff/rough) and replacing the straight grease fitting with a 90 deg. elbow fitting...the straight fitting would not allow you to grease the unit with the frame in the way. Anyway, no slop in the unit and it works well once massaged.
The PO did a nice job on the car and actually it didn't need rebuilding yet (obviously he didn't drive it much) but you don't know that til you take everything apart and it's nice to know how everything works.
p.s. I did find (during dis assembly) though that both the left and right tie rod levers (attached to the vertical link(s)) had worked slightly loose even though they were secured with the proper nyloc nut...that bears checking.
TR4
What, no photos so we can see your handiwork? It's always nice to see the finished product after all the hard work is done. Good to hear all is well now.
prb51
prb51
Not much of a picture taker, looks pretty much like the other guys work.
I posted to comment on the poly bushings as a recent thread here was refering to a squeeky front end and I was surprised that there is no noise at all (I'd heard poly could be loud)and I accidentally only anti seized one side so I did an unplanned 'test'.
The other was to mention the loose tie rod levers (both sides)...
prb51
prb51
Everything is pretty straightforward as per the manuals.
Take the time to keep your brake discs clean and lube free whilst doing everything.
It can get pretty tight removing the shock/ rebound plate as you need to jack the assembly up to remove both, a solid piece of wood block on my hyd jack worked fine. Just use extensions and keep your fingers out of the way for safety until you get the coil spring bolted thru with your spring compressor. Another easier way is to remove the rebound plate and shock while the wheel is on the ground and thread the coil compressor prior to jacking the car up, awkward but doable and safe.
I also used a jackstand with a wood block to support my brake caliper out of the way and that left plenty of room to work.
I used a micrometer to measure the length of my tie rods, from the end of the securing nut to the center of the tie rod ball joint, so I could set up my new ball joints as close a poss...worked perfectly as I've remained true with 1/8" toe in. Take your time and remeasure as it works well if your car is already running true.
When you reassemble the lower elements they must be done simultaneously, lower inner arms on their bushings while you put the new trunion in place, that's not articulated well in the manual but is a common sense thing you'll note when rebuilding.
The first side took a bit of time as I went slowly but the second effort went pretty quickly.
If you have any questions while you're doing it let me know as it's pretty fresh in my mind.
Note what I said if you are purchasing a new idler arm assembly, mine needed some work on the threads to be smooth and the zerk was wrong for the position.
I did enjoy the process though and tidied up everything nicely, good project.
Don Elliott
I assume that you had the engine in the car. The weight of the engine makes the job easier. If, during a total body-off restoration (or for any other reason) the engine is not on the frame, It will be almost imposible to compress the front coil springs to get it all back together again.
I have heard of one fellow who placed 12 concrete patio tiles on his frame because the engine was out. Another chap (in England I think) was doing a front suspension task in the little garage he had behind his house. Because the engine was out and the frame kept lifting off the jack stands, he wedged a 4" by 4" between the frame of the car and the rafters supporting the roof of his garage. But it didn't work.
All he did was lift the whole roof off the garage.
prb51
prb51
Don,
Yes, engine in the vehicle. Even then you can lift the car off it's jackstands compressing the springs. Don, I missed you at Triumphest. I could only make it Sat and arrived about 1130 and took off around 3 pm. I live just 2.5 hours from the hotel. You were probably on the 'run'. For a few hours I think I had the only small mouth there (other than a few TR3a's with small mouth aprons fixed). Nice place for a meet and I did get to see many of the cars still on the lawn/ parking lot.
Tdskip,
Almost forgot the most important activity; reaming the new lower outer bushings.
I punched the old bearings out with a socket and socket extension and then had them pressed in. If you have a bearing drift you could do this yourself (a bearing drift has a lip that extends inside the bearing keeping it the appropriate diameter as it is 'punched' in). I didn't so took it to the local garage. It only takes a second to press them in and he didn't charge me because of that.
I used a 5/8ths reamer;
https://www.use-enco.com/CGI/INSRIT?PMAKA=331-1140&PMPXNO=945503&PARTPG=INLMK32
from Enco and some WD40. Once you have the reamer started and centered (susp arm in a vise) you can put a small visegrip on the shaft of the reamer for a better purchase as you pull thru. Back it out often and clean the cutting grooves. It came out to a very nice slide fit with no slop.
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
R TR2/3/3A TR3 Front Suspension and Steering Triumph 12
ekamm TR2/3/3A Tr3 front suspension clarification Triumph 4
ekamm TR2/3/3A Tr3 front suspension Triumph 16
Moseso TR2/3/3A TR3 -->4 Front suspension upgrade questions Triumph 7
I TR2/3/3A TR3, front suspension rebuild qustions Triumph 13
I TR2/3/3A TR3, Front Suspension Triumph 7
S TR2/3/3A TR3 front suspension problem Triumph 17
K TR2/3/3A TR3 Front suspension rebuild question...... Triumph 5
K TR2/3/3A TR3 front suspension blow up pic? Triumph 6
K TR2/3/3A Another TR3 Front Suspension Rebuild Question Triumph 5
K TR2/3/3A TR3 Front Suspension Rebuild Pics....Lost the link Triumph 0
fad64b TR2/3/3A TR3 Front Suspension Triumph 17
T TR2/3/3A TR3 question - front suspension rebuild access Triumph 7
T TR2/3/3A Poly bushings for TR3 front suspension Triumph 7
PeterK TR2/3/3A TR3-4 Front suspension question Triumph 7
K TR2/3/3A TR3 alloy wheels and Front suspension upgrades Triumph 14
martx-5 TR2/3/3A TR3 front suspension Triumph 2
G TR6 TR6 front suspension in a TR3 Triumph 3
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
S TR2/3/3A tr3 front apron body work Triumph 9
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
