TR2/3/3A TR3 front apron
T
twcguy
I also noticed that TRF has front aprons on "sale" for $2,299. Does anyone have any experience with the aprons from Moss or TRF?
TR3driver
Great Pumpkin - R.I.P
I assume you mean other than being for a TR3A :laugh:
Hard to say from those photos; can't tell if that is just variations in surface finish or if it has ripples all over. I see some damage around one of the bumper mount holes; and at least one captive nut missing. The edge next to the hood doesn't look straight, but again that could be just surface finish/light. One of the side flanges is definitely somewhat out of shape, but that's no big deal either.
So, I'd call it 'decent' in the sense that it can be relatively easily repaired (with a skin of Bondo). But it's not ready to install, IMO.
apbos
twcguy
What does yuour apron look like? I would think using Randall's apron for patching might be a better choice. The ebay apron would still need some work and it has not meet the reserve. Plus you've still got to ship it. I do know of a early TR3 apron ($200) and grill ($30) in good shape here in N Cal (not mine)and not the one in Sac that has been listed for months with rust issues.
Paul
Andrew Mace
TR3driver said:
Hard to say from those photos; can't tell if that is just variations in surface finish or if it has ripples all over....So, I'd call it 'decent' in the sense that it can be relatively easily repaired (with a skin of Bondo). But it's not ready to install, IMO.
:iagree: Interestingly, it appears to have no holes for letters (of either style). If so, it's possibly a later Stanpart replacement part or possibly even one of the Tasker Metal Products replacements that J.C. Whitney and others used to sell (not bad quality, as I recall).
John_Mc
here are some parts I noticed on our local CL:
TR3 parts
Looks like it may be a small mouth apron. Not sure. No financial interest.
apbos
John
That is the apron I looked at. It is a small mouth. It looks good.
Paul
S TR2/3/3A tr3 front apron body work Triumph 9
toysrrus TR2/3/3A "WANTED": TR3 Small Mouth Front Apron Medallian Triumph 14
K TR2/3/3A Mounting TR3 Body to frame with front apron on? Triumph 4
M TR2/3/3A Fitting front apron TR3 Triumph 12
mountainman TR2/3/3A Tr3 Front Apron Triumph 17
T TR2/3/3A TR3 front apron removal - tips and suggestions Triumph 11
H TR2/3/3A TR3 Front Apron Removal Help Triumph 26
gsalt57tr3 TR2/3/3A TR2 vs TR3 front apron Triumph 4
K TR2/3/3A TR3 front air vents mounted under the grill...seen on race cars for better air flow to radiator. Triumph 1
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
K For Sale TR3 front passenger side fiberglass floor panel.....$100 CAD OBO plus shipping. Triumph Classifieds 3
T TR2/3/3A tr3 front carpet replacement Triumph 5
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
B TR2/3/3A 'A' type Front calipers, TR3 vendor??? Triumph 7
jfarris TR2/3/3A Front Sway Bar on a 56 TR3 Triumph 13
F Wanted TR3 Front Float Bowl Lid SU H6 Triumph Classifieds 6
T TR2/3/3A Pictures of my TR3 with over riders on front Triumph 14
S TR2/3/3A tr3 front fender Triumph 4
B TR2/3/3A TR3 Front Hub Felt Seal questions Triumph 2
Got_All_4 TR2/3/3A Tr3 front suspension re-bush, what's good out there Triumph 15
sqbsprite TR6 Do the TR3-6 front spring pans interchange? Triumph 6
G TR2/3/3A Front Sway Bar Installation on Wide Mouth 61 TR3 Installation Problem? Triumph 9
charleyf TR2/3/3A Front wheel bearing--inner tr3 Triumph 4
Tinkerman TR2/3/3A 1960 tr3 a petrol tank front millboard question Triumph 6
BillyB62 TR2/3/3A TR3 front end shake Triumph 24
BillyB62 TR2/3/3A TR3 Ball joints & front end Triumph 5
mgbmedic TR2/3/3A Modern Seal for Front Wheel Bearings TR3 Triumph 8
T TR2/3/3A Vent hole in lower front valance of TR3? Triumph 7
luke44 TR2/3/3A TR3 Front Fender Washers? Triumph 19
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 2
mgedit TR2/3/3A TR3 Front Banjo Connectors Triumph 7
T TR2/3/3A TR3 front license plate Triumph 4
mgedit TR2/3/3A Front Drum Brakes 56 TR3 Triumph 2
PatGalvin TR2/3/3A TR3 Engine Front Sealing Block, Oil Pan Screw Size and Thread Pitch? Triumph 11
BillyB62 TR2/3/3A Front Float Cover Lid for TR3 H6 Carb Triumph 10
AHS TR2/3/3A Which way does the TR3 front crankshaft oil seal face? Triumph 8
Kleykamp TR2/3/3A TR3 Front Emblem??? Triumph 7
Scotsman TR2/3/3A tr3 front wheel hub stud removal Triumph 2
Tr3aguy TR2/3/3A TR3 Front suspension breakdown..Help Triumph 2
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
AEW TR2/3/3A TR3 engine front cover repair Triumph 10
O TR2/3/3A TR3 front End Alignment Triumph 8
B TR2/3/3A Fitting the front wing 57 TR3 Triumph 2
B TR2/3/3A Installing front fenders on TR3 from TRF Triumph 12
Kleykamp TR2/3/3A TR3 Front Suspension rebuild????? Triumph 12
C TR2/3/3A Where to buy front calipers for an early[57] TR3? Triumph 7
S TR2/3/3A front bumper override tr3 Triumph 6
