TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where?
luke44
I would like to get some guidelines as to where the panel screws should be located. I have checked my archive of pix and they seem to be all over. Can someone provide anything definitive? I will show a few from my collection of pix I have accumulated - some look good, some look just wrong, and no two look the same... Thanks in advance,
Pic 1 Comment/Question: too few along the curved front section? (should have 4, not 2?)
Pic 2 Comment/Question: one too few across top?
Pic 3 Comment/Question: 1 more than the number of holes along bottom compared to mine, otherwise looks good?
Pic 4 Comment/Question: an older piece but too few along curved front section?
Pic 6 Comment/Question: strange spacing along top but may be a different series - TR2 or TR3 vs TR3a or something?
Pic 7 Comment/Question: Too many along top?
luke44
luke44
OK, all things considered after looking at a number of pictures, a few books and the holes in my door, I think the proper number of panel screws is 14, locations as shown. What say ye? Comments?
Lou Metelko
My TR2 was done by the side screen interior master, Larry Learn in Indiana, Pennsylvania and there are 15 screws. The difference between the immediate above and mine is I have five screws at the top rail versus four. The biggest sin is haveing too thick padding under the vinyl giving a sunk in look to the screws.
Lou Metelko
Auburn, Indiana
mrv8q
Just went outside to compare yours to mine; they are the same. For some reason, my #9 and 10 always need to be tightened. HTH!
luke44
luke44
....there are 15 screws. The difference between the immediate above and mine is I have five screws at the top rail versus four...Lou Metelko Auburn, Indiana
Hi Lou - by "top rail" you mean my screws numbered 4-5-6 and 7? I recall your car is an early 3 or maybe even a 2? I can't remember since it was 2010 when I last saw it, but I wonder if it is different than a 3A? I noticed in pic 6 in my first post there is an extra screw across the top like you mentioned. The car in pic 6 has the wedge fitting for the side screens which I believe is indicative of an earlier car. Perhaps there was a changeover and a screw got deleted?
CJD
My impression is that it depended who was on shift that day at the factory and how his mood was!?!
When repanelling mine, I used the factory holes and an ice pic. The ice pic finds the holes and then a small drill opens the panel for the screw. One or two holes were oversized from years of abuse...but a little tapping with a hammer and dolly got them back to size. I count 16 screws.
RC64
Bruce...
I'm also getting ready to recover the door panels on my 59 TR-3A. I have the "original" panels and the holes are exactly as you have them layed on in your photo.
Rick...
PatGalvin
No to hijack the thread, but what screws and cup washers did you use (and from where did you source them)?
Thanks to all the posters for this great thread.
Pat
mallard
Check out this Item # on ebay 400535246528 This is where I got my screws and washers. More than what you will need. I got the 1" screws because the ones form the big 3 can be short at times. Not hard to cut them if you need to. (#4 trim screws)
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
B TR2/3/3A Door / rocker panel relationship TR3 Triumph 11
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
S TR2/3/3A wood next to the door on a tr3 Triumph 4
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
J TR2/3/3A door gaps on a TR3 prior to paint Triumph 13
Kleykamp TR2/3/3A TR3 cowl vent door spring Triumph 3
Kleykamp TR2/3/3A Interior door pulls on TR3?? Triumph 5
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
T TR2/3/3A TR3 Door seals Triumph 6
Kleykamp TR2/3/3A TR3 Door hinge hole pattern??? Triumph 12
B Door Capping on a TR3 Restoration & Tools 0
mgedit TR2/3/3A 56 TR3 Door Question Triumph 8
PatGalvin TR2/3/3A TR3 Door Rebuild Weatherstripping Question Triumph 10
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
CJD TR2/3/3A TR3 Door Scuff Panels Triumph 4
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
S TR2/3/3A TR3 Exterior Door handles Triumph 4
CJD TR2/3/3A TR3 Rear Door Seal? Triumph 2
T TR2/3/3A TR3 door gap Triumph 12
S TR2/3/3A door check straps for tr3 Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
T TR2/3/3A TR3 inside door linkage Triumph 8
T TR2/3/3A TR3 door sills Triumph 2
S TR2/3/3A tr3 door too tight Triumph 1
M TR2/3/3A TR3 door hinge repair ??? Triumph 3
mountainman TR2/3/3A TR3 Door Seals Triumph 8
F TR2/3/3A recovering the door and dogleg cappings on the tr3 Triumph 4
luke44 TR2/3/3A TR3 Inner Door Handle Parts Triumph 16
G TR2/3/3A TR3 Door Hinge Problem Triumph 4
ekamm TR2/3/3A TR3 door cap button Triumph 4
B TR2/3/3A TR3 Door hinge removal fun! Triumph 5
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
mountainman TR2/3/3A Tr3 Door Cap Triumph 7
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
S TR2/3/3A top door trim tr3 Triumph 4
CraigLandrum TR2/3/3A TR3 door fitting tips? Triumph 16
S TR2/3/3A tr3 door Triumph 4
martx-5 TR2/3/3A TR3 Furflex - Fuzzy Door Seals Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
CCURTISS TR2/3/3A New TR3 Leather Door Pull Straps Located Triumph 4
S TR2/3/3A door strap checking tr3 Triumph 8
gsalt57tr3 TR2/3/3A TR3 Door Cord Question Triumph 3
Earl TR2/3/3A TR3 Door Parts Triumph 6
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
