TR2/3/3A TR3 Door seals
tomgt6
Another question for the experts.
How does the seals go on around the doors? I see a rubber seal that goes on the bottom, does it go on the bottom of the door or on the sill? What type of glue do you use to do this?
Also does the furflex go all the way around the door or only up the sides? It looks like you use contact cement to glue this down?
Sorry for all the questions but it doesn't always explain some of this in the manuals I have as well as I am working on someone else's car and either there have been changes made along the way or some stuff is so far gone I can't tell how it goes.
Thanks
MGTF1250Dave
Aloha Tom,
The seal is mounted on the bottom of the door by a several small metal clips that attach to the base of the seal. The metal clips then are inserted into the holes (approximately 1/4" diameter) that are in the bottom of the door. These may have been filled in with body filler if you don't see them. There has been some recent discussion that replacement seals don't often compress sufficiently to allow the door to close. Here is a link to that discussion you might find helpful:
https://www.britishcarforum.com/bcforum/u...oors#Post831853
There is also a seal mounted on the upper part of the "A" pillar in the same matter. It is about about 12" long. I would suggest that you let the rubber "relax" for about a week after you install it before you trim to fit.
The furflex goes on the "A" and "B" pillars. An aluminum trim piece covers the joint of the sills along the base of the door frame and is held in place by sheet metal screws.
CJD
The fur flex goes just front and back. It staples at the back and screws at the front with the carpet reinforcement.
The lower seal goes on the door, BUT! If it is a repo, it will not fit. The new seals are too thick to let the doors close...at all! If you have to try it, like I did, then they are held with a bunch of small clips. Also of note, even with the proper original seals, these clips will pull out and scratch the sill and door before you realize they are loose. Bummer!
Actually, all lower seals should be left out on the 3's...otherwise when it rains the leaks will overpower the drains...and you may not be able to pull over before you drown....
John
T
tomgt6
Thanks for the help guys. Does anyone have some pictures as well?
angelfj1
Not sure which seals you mean. here are some photos of the bottom edge seal. This is a special "modified" seal that I discuss in another post.
T
tomgt6
Thanks Frank.
Do you happen to have pictures of the A and B pillar seals on the car?
Scotsman TR2/3/3A TR3 door weather seals Triumph 22
mountainman TR2/3/3A TR3 Door Seals Triumph 8
newmexTR3 TR2/3/3A TR3 Aftermarket Door Seals that work? Triumph 11
martx-5 TR2/3/3A TR3 Furflex - Fuzzy Door Seals Triumph 4
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
S TR2/3/3A wood next to the door on a tr3 Triumph 4
B Wanted WTB: TR3 Late model-"Round bottom" door Triumph Classifieds 4
Tinkerman TR2/3/3A 1960 TR3 A Door Check Assembly Triumph 13
Tinkerman TR2/3/3A DOOR PANEL HELP NEEDED 1960 TR3 A post 60000 car Triumph 5
luke44 TR2/3/3A TR3 Door Panel Screws - Location - How Many and Where? Triumph 10
J TR2/3/3A door gaps on a TR3 prior to paint Triumph 13
Kleykamp TR2/3/3A TR3 cowl vent door spring Triumph 3
Kleykamp TR2/3/3A Interior door pulls on TR3?? Triumph 5
Tr3aguy TR2/3/3A Looking for a passenger door!!! TR3 Triumph 20
Kleykamp TR2/3/3A TR3 Door hinge hole pattern??? Triumph 12
B Door Capping on a TR3 Restoration & Tools 0
mgedit TR2/3/3A 56 TR3 Door Question Triumph 8
PatGalvin TR2/3/3A TR3 Door Rebuild Weatherstripping Question Triumph 10
F TR2/3/3A TR3 interior mystery question- door pull handles Triumph 9
CJD TR2/3/3A TR3 Door Scuff Panels Triumph 4
toysrrus TR2/3/3A TR3 Door Wood; Who sells them? Triumph 1
S TR2/3/3A TR3 Exterior Door handles Triumph 4
CJD TR2/3/3A TR3 Rear Door Seal? Triumph 2
B TR2/3/3A Door / rocker panel relationship TR3 Triumph 11
T TR2/3/3A TR3 door gap Triumph 12
S TR2/3/3A door check straps for tr3 Triumph 1
M TR2/3/3A ?????Early TR3 door fitting problem ????? Triumph 22
T TR2/3/3A TR3 inside door linkage Triumph 8
T TR2/3/3A TR3 door sills Triumph 2
S TR2/3/3A tr3 door too tight Triumph 1
M TR2/3/3A TR3 door hinge repair ??? Triumph 3
F TR2/3/3A recovering the door and dogleg cappings on the tr3 Triumph 4
luke44 TR2/3/3A TR3 Inner Door Handle Parts Triumph 16
G TR2/3/3A TR3 Door Hinge Problem Triumph 4
ekamm TR2/3/3A TR3 door cap button Triumph 4
B TR2/3/3A TR3 Door hinge removal fun! Triumph 5
Brooklands TR2/3/3A Spare Wheel Door rubber gasket - TR3 Triumph 3
mountainman TR2/3/3A Tr3 Door Cap Triumph 7
W TR2/3/3A TR3 Door Seal Rubber Question photo request Triumph 4
S TR2/3/3A top door trim tr3 Triumph 4
CraigLandrum TR2/3/3A TR3 door fitting tips? Triumph 16
S TR2/3/3A tr3 door Triumph 4
Russ Austin TR2/3/3A Door Check Strap TR3 Triumph 10
CCURTISS TR2/3/3A New TR3 Leather Door Pull Straps Located Triumph 4
S TR2/3/3A door strap checking tr3 Triumph 8
gsalt57tr3 TR2/3/3A TR3 Door Cord Question Triumph 3
Earl TR2/3/3A TR3 Door Parts Triumph 6
PeterK TR2/3/3A How do I remove TR3 door capping Triumph 6
