TR2/3/3A TR3 Cylinder Liner Install Question
PatGalvin
Good morning all.
I'm installing new TR3 cylinder liners this week. From the Service Manual, it indicates the liners should stand proud of the block top deck by about 0.005" and it shows how to measure this with a feeler gauge and straight edge. So, I'd apply the Wellseal, fit the figure eight gaskets, and install liners. Do I apply substantial pressure to the liners before I measure the liner/top deck relationship? Torque down head? Hand pressure? I assume that one needs to apply some pressure to top of liners to seat them prior to taking this important measurement. Thanks again the the forum for all the help!
Pat
JKB1957
I would dry fit the liners first, take measurements, and then go from there. I used fender washers and lengths of pipe to set the liners in the block and keep them there when I installed the pistons/crank. The liners can shift when you flip the engine to install the bottom end. They were a very tight fit going in, and once they bottomed out they were spot on for 0.005". One thing I did do was to make sure the flange where the liners sit was absolutely clean of scale and rust and then use a very light coat of permatex on the figure "8" gasket. This was good advice from a friend who had rebuilt a TR3 engine several years before. Good luck. Actually we have a group of TR people here in Contra Costa County, not to far from you. If you run into problems send me a PM amd if I can't help, probably someone else in our group can.
TR3driver
Great Pumpkin - R.I.P
:iagree:
except don't bother with a "dry fit" first. Clean the seats, apply the Permatex, seat the liners and go.
Be sure to measure the liner protrusion on both sides. I've had two TR3 engines in a row now where it wasn't high enough only on one side, and had a lot of trouble with leaking head gaskets before I found the problem (and a workaround).
PatGalvin
PatGalvin
How do you seat the liners so you can take a proper measurement? Use big flat washers and push down? Or press down manually?
And what was your workaround when liners weren't high enough on one side (I'm sure I'm not the only one who wonders this)?
Thanks Randall
Pat
NickMorgan
It's a long time since I did mine, but after making sure that everything was really clean I pressed them in as far as I could by hand and then knocked them in using some wood to cushion them. There was no way I could have dry fitted them as it is a bit of a struggle to get them in, and more of a struggle to get them out! Maybe it was luck, but they seemed to fit perfectly and I didn't have any trouble with how far they protruded from the block.
Good luck.
TR3driver
I tapped mine in using a brass hammer.
Workaround was to lay a piece of 20 AWG "half hard" copper wire up against the stock fire ring, and tack it in place with soft solder. I first did that on my TR3A (which had an earlier TR3 block in it) many years ago; then more recently repeated it on the 'project' TR3 after it's headgasket started leaking (and measurements confirmed at least one liner was low on the manifold side).
No doubt there are other methods, and of course it would be best to address the problem properly (by having the block remachined). But the workaround held fine for quite a few years on the TR3A, and this got me back on the road quickly. Maybe someday I'll find time to build a "hot rod" motor and get it right, but in the meantime ...
:driving: :driving: :driving:
Mike62TR3
Randell, so maybe i am just missing something, what happens with the solder? won't this affect the seating for compression?
Mike E. 62 TR 3A
K TR2/3/3A Clutch Slave Cylinder location when TR3 has a TR6 Gearbox? Triumph 16
J TR2/3/3A TR3 engine cylinder top clearance Triumph 22
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
A TR2/3/3A TR3 door handle lock cylinder Triumph 4
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
mgedit TR2/3/3A Master Cylinder 56 TR3 [Lockheed] Triumph 14
mgedit TR2/3/3A Lockheed Master Cylinder 56 TR3 Triumph 2
K TR2/3/3A Can porting a TR3 Cylinder head be a DIY job? Triumph 6
G TR2/3/3A TR3/TR4 Cylinder Head Gasket SElection Triumph 2
M TR2/3/3A TR3 slave cylinder, What I'm I doing wrong Triumph 2
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
B TR2/3/3A TR3 Cylinder Sleeve Installation Triumph 10
mgedit TR2/3/3A 56 TR3 Master Cylinder Issues Triumph 17
mgedit TR2/3/3A Master Cylinder 56 TR3 Triumph 3
K TR3/4 Cylinder head temperatures? Racing 1
K TR2/3/3A The Aluminum Plug in the Cylinder Head ?[Again]TR3 Triumph 2
PeterK TR2/3/3A Classic Gold TR3 Master Cylinder Triumph 2
T TR2/3/3A TR3 clutch slave cylinder Triumph 14
mrv8q TR2/3/3A TR3 Clutch Master Cylinder Triumph 20
Marvin Gruber TR2/3/3A TR3/4 cylinder head differences Triumph 3
mountainman TR2/3/3A TR3 slave cylinder adjustment Triumph 4
Tinkerman TR2/3/3A TR3 Master Cylinder Box Mounting Triumph 9
H TR2/3/3A TR3 Master Cylinder Removal Triumph 5
Q TR2/3/3A TR3 Brake Master cylinder rebuild Triumph 5
mountainman TR2/3/3A TR3 Rear Whelel Cylinder Install Triumph 10
P TR2/3/3A TR3 Slave Cylinder Return Spring Triumph 3
TR4nut TR4/4A Aluminum plug in TR3-4A cylinder head? Triumph 4
RedTR3 TR2/3/3A TR3 Clutch Slave Cylinder Adjustment Triumph 3
martx-5 TR2/3/3A Follow-up on TR3 Master Cylinder Resevoir Triumph 2
RedTR3 TR2/3/3A TR3 Cylinder Heads Triumph 10
J TR2/3/3A TR3 Master Brake Cylinder Stripped Fitting Triumph 1
martx-5 TR2/3/3A TR3 Ignition Lock Cylinder Triumph 3
txtr3 TR2/3/3A TR3 master cylinder replacement hints Triumph 3
S TR2/3/3A tr3 slave cylinder quality Triumph 8
E TR2/3/3A TR3 Cylinder Head Lubrication Triumph 11
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
