TR2/3/3A TR3 Brake pads interchangeable?
ctp
I am wondering which brake pads are interchangeable. My local parts stores definitely do not have TR3 pads. I know I can order these but I hate to wait. It looks like later Triumphs, even a TR6 pad is the same size and shape. Are they interchangeable? Does anyone know of a place near Central Ohio to get some?
martx-5
If you're talking about your '57 TR3, then I would say NO. That would be the first disc brake set-up that went from commission numbers TR3 from TS13046, TR3A to TS56376. After that, the calipers and pads changed.
K TR2/3/3A A quote from Randall on Brake & MC Pedal Stops on later TR3's Girling system Triumph 2
K TR2/3/3A TR3 Brake MC pushrod? Triumph 0
T TR2/3/3A Has anyone designed a hand brake warning light for the TR3? Triumph 3
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
S TR2/3/3A brake reservoir on a tr3 Triumph 8
A TR2/3/3A TR3 Brake / Clutch Resevior & Lines needed Triumph 2
K TR2/3/3A TR3 brake fluid reservoir outlet at the bottom..... Triumph 0
K TR2/3/3A TR3 Brake drums on a 1956? Triumph 5
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A One Person TR3 Brake Bleeding Option? Triumph 11
mgedit TR2/3/3A Brake Light Switch 56 TR3 Triumph 3
T TR2/3/3A What is thread size on TR3 brake light switch? Triumph 5
mgedit TR2/3/3A Brake Line Master to Banjo Connection LHD 56 TR3 Triumph 4
mgedit TR2/3/3A Routing of Clutch and Brake Pipes from MC 56 TR3 Triumph 7
mgedit TR2/3/3A Source for Brake Pipe 56 TR3 Triumph 9
JFeher TR2/3/3A TR3 Type "A" front brake caliper rebuilding Triumph 17
D TR2/3/3A TR3 brake rotor question Triumph 4
J TR2/3/3A Brake line advice for my TR3 Triumph 5
L TR2/3/3A TR3 Brake Rotor Thickness Triumph 18
T TR2/3/3A tr3 brake/clutch reservior question Triumph 1
K TR2/3/3A TR3 Brake & Master Cyl "C" clips? Triumph 2
K TR2/3/3A Generic TR3 Brake Light Switch? Triumph 3
K TR2/3/3A TR3 10" Brake Drums? Triumph 10
af3683 TR2/3/3A Original Paint on TR3 Brake Drums Triumph 1
K TR2/3/3A TR3 Brake Proportioning Valve? Triumph 2
S TR2/3/3A rear brake lines tr3 Triumph 3
mgedit TR2/3/3A 56 TR3 Clutch/Brake Pedals Triumph 4
Got_All_4 TR2/3/3A TR3 E brake problems Triumph 19
Got_All_4 TR2/3/3A What's wrong with this brake fluid? TR3 Triumph 19
S TR2/3/3A Should TR3 rear brake slave cylinders move? Triumph 4
K TR2/3/3A Installing Brake Switch TR3? Triumph 6
B TR2/3/3A TR3 brake restrictor valve Triumph 6
J TR2/3/3A TR3 Lockheed brake/clutch MC bracket... Triumph 11
K TR2/3/3A TR3 Rear Brake back plate... Triumph 2
K TR2/3/3A TR3: diff oil on the rear brake shoes... Triumph 4
J TR2/3/3A tr3 hydraulic brake light switch Triumph 13
K TR2/3/3A TR3 rear brake adjuster seized? Triumph 10
T TR2/3/3A tr3 rear brake band installation question Triumph 7
S TR2/3/3A tr3 e-brake handle Triumph 4
T TR2/3/3A TR3 front brake line routing Triumph 3
S TR2/3/3A tr3 brake restrictor Triumph 14
NutmegCT TR2/3/3A TR3 brake [?] squeak Triumph 14
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
S TR2/3/3A brake lines and rubber bumpers tr3 Triumph 12
Moseso TR2/3/3A TR3 Brake/Turn Lighting Improvement Discussion Triumph 12
mountainman TR2/3/3A TR3 Rear Brake Position Triumph 11
T TR2/3/3A Tr3 brake calipers Triumph 3
CraigLandrum TR2/3/3A TR3 front disk brake squeal cause? Triumph 11
