Torquing crankshaft bolt
TulsaFred
What's the best way to torque the crank bolt without just rotating the engine?
I could stick a piece of 2x4 in the crakcase and wedge it between the block and crank, but I'm afraid I'll crack the block with the high torque needed.
Fred
JPSmit
I stuck a piece of 2X4 - worked fine.
TulsaFred
TulsaFred
OK the 2x4 worked fine to put 70 ft lbs on the crank bolt.
But what if you don't have the oil pan off?
jlaird
Then it becomes a bit more trickie, You feed a length of rope into one of the spark plug holes so when you turn the engine the rope stops it from turning. Then as you have carefully left a bit hanging out of the plug hole you pull it out after your torque the bolt.
JPSmit
or you jam the flywheel
K TR2/3/3A Retorquing the Cylinder Head after the initial torquing.? Triumph 23
P Help with torquing bolts Restoration & Tools 3
steveg TR6 Loose wheel nuts after torquing Triumph 2
T TR2/3/3A Question on torquing nut on steering box rocker shaft Triumph 8
banjojambo TR2/3/3A TR3A Re-torquing Head Nuts Triumph 7
Bob_Spidell Re-torquing Head Nuts Austin Healey 4
Got_All_4 Wedge TR7 drive train torquing Triumph 2
T TR4/4A Question on re-torquing the head if it has leaked Triumph 18
T TR4/4A Any tips on re-torquing TR4a head now that 500 are on the rebuild Triumph 7
T lubing trans input shaft splines; torquing pressur Spridgets 2
JPSmit re-torquing question Spridgets 2
Michael Oritt Torquing/Retorquing cylinder head Racing 7
tahoe healey Head torquing Austin Healey 1
M Block threads stripped torquing head Triumph 16
G Re-torquing the head Triumph 1
G Torquing rocker pedestal changed clearances Triumph 1
D Torquing Procedure Racing 16
G Re-Torquing my Head Gasket....... Triumph 4
G Torquing a Head Triumph 17
Michael Oritt Looking for a good 100 crankshaft Austin Healey 3
56HealeyDan 100-4 Front Crankshaft Seal Austin Healey 2
B TR6 Crankshaft long seal surface Triumph 5
MKIII_Joey Crankshaft Bearing Austin Healey 7
BT7 Owner Rear Crankshaft Bearing Cap Austin Healey 4
K TR2/3/3A " do not remove the fan as it is essential for establishing crankshaft balance" Triumph 9
B General MG Crankshaft Nut Removal MG 4
W Crankshaft Oil Seal Austin Healey 3
Popeye TR4/4A Crankshaft pulley recommendations: One piece alloy, two-piece steel, wide, narrow...? Triumph 12
B MGB Mgb crankshaft end play shims MG 2
M TR2/3/3A 1958 TR 3 , crankshaft nut for hand starting Triumph 7
M TR2/3/3A Crankshaft Sludge Plug Removal Triumph 6
T crankshaft (rear) bearing leak Spridgets 2
T Wanted Wanted - 1956 TR3 Crankshaft Triumph Classifieds 0
R Wanted 3 main crankshaft MG Classifieds 0
glemon TR2/3/3A Crankshaft Question Triumph 3
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
AUSMHLY Crankshaft Starter Nut Austin Healey 10
S For Sale Mg t-series crankshaft tb tc td tf 1250 1500 MG Classifieds 0
K TR2/3/3A Anyone have a picture of the crankshaft pulley.... Triumph 1
S Wanted Looking for a new/used crankshaft for a 100-4 Austin Healey Classifieds 0
P TR2/3/3A Crankshaft Thrust Washers Triumph 4
M TR2/3/3A Crankshaft Pulley Configurations Triumph 3
M TR2/3/3A Crankshaft Oil Galley Plugs Triumph 7
S TR4/4A Fair price for a crankshaft? Triumph 2
charleyf TR2/3/3A crankshaft hardening Triumph 2
Gerard Wanted: 1275 Crankshaft Spridgets 3
T can't find timing marks on 1275 crankshaft pulley/damper Spridgets 8
G Crankshaft Rotational Freeplay - What's going on with this engine? Austin Healey 12
O Wanted TR 3 Crankshaft please... Triumph Classifieds 1
P Replacing the crankshaft damper [harmonic balancer] Austin Healey 15
