G
I installed my newly ground head at 70 lbs. of torque using new ARP chrome-moly head bolts. After about 100 miles I re-torqued the head to 75 lbs. but think I should have done more. I now have about 300 more miles on the engine and I would like to try retorquing again to at least 80 lbs. I don't know if I am be paranoid or what but there seems to be a little wetness (can't tell if it is oil or coolant), very little, on the plug side of the head. I did lay a very fine bead of sealant around the coolant passages in this area only, not around the cylinders of course. What is the consensus with head bolt torque, considering the type of bolts I have, the fact that the head has been shaved (9.5:1 comp) and the fact that I am paranoid.
Bill
Bill
