Torque values needed for 100
Michael Oritt
I need the torque values for the nuts that go onto the front of both the crankshaft and camshaft--in front of the timing chain sprockets under the front cover.
There is nothing in the manual and I would like to get these right.
If it matters this is for a DW steel crank and DW fast street camshaft.
This is for a 100.
Thanks in advance.
roscoe
Just so you know someone read your post....as you know there is no value for those torques in the book. Perhaps an email to DW racing will at get you the Newton meter numbers you need. As I recall I used German torque on those. Gutund tight. So far so good.
Michael Oritt
Michael Oritt
Roscoe--
Thanks for that German specification, about as useful as the common American value of "Tighten till stripped, then back off 1/2 turn".
Healey Nut
Roscoe--
The other method is counting the viens in your temples as they stand out with the tightening strain .
2 veins is about 80ft lbs .
Michael Oritt
Michael Oritt
I received some information and suggestions over on the AHX 100 forum which, because it reaches out to 100 owners, is a bit more application-specific, though the design of the spring-lock washer is, I believe, common to al Big Healeys.
See this thread if you are interested:
https://www.ahexp.com/phorum/read.php?4,201202
D torque values Austin Healey 2
I Torque values for front suspension? Spridgets 3
I Bugeye torque values? Spridgets 3
Westfield_XI Differential torque values Spridgets 9
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
S TR2/3/3A Torque specification on large pitman arm nut Triumph 1
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
