Differential torque values
Westfield_XI
I am finishing up the installation of a Phantom Grip LSD unit in my Spridget diff. I need the torque values for the 6 bolts that hold the crown wheel to the differential cage, and the 4 bolts that attach the bearing caps to the differential carrier. Haynes doesn't list these values.
jlaird
Bolts are torqued baised upon their size. Do a web search it's out there some place, I've seen it.
Bugeye58
Mike, the bearing caps are torqued to 65 ft. lbs. I can't find anything written for the ring gear bolts yet, and I won't trust to memory for someone elses use. I'll keep digging.
Jeff
JerryB
""""""I need the torque values for the 6 bolts that hold the crown """"""
Depends on the bolts you are using. Certainly dont reuse the originals if your going to "spin the tires" or work the car hard...same goes for those goofy tab locks. Dont use em.
You need a specific grip length on the bolt and also a hardened and ground shim (washer) with a chamfer on the bolt head side i.d. Drilled head for safety wire and red loctite at 45' #. I'd peruse ARP pieces or something G8 which will have too much thread and have to be cut to fit and the heads drilled.
If this is just a low hp driver then use anything thats handy..(I guess).
"""""""e 4 bolts that attach the bearing caps to the differential carrier"""""""
They are studs...not bolts. Use new hardened and ground both sides shims and G8 full height nuts or better yet 12 point washer faced nuts. Klee-n-prime and red loctite as above.
You can substitute blue loctite but you MUST clean and prime correctly.
Sounds like overkill??
Loosing a ring gear at 70 mph is not fun.
jlaird
Wow, guess that is all important with big torque engines and high HP.
Glad I don't have to learn/do all that.
Westfield_XI
Westfield_XI
And where does one obtain such shim/washers? I can drill the bolt heads, have a fixture for that, but i have no idea where to get precision ground, hardened, chamfered washers.
Deleted member 3577
[ QUOTE ]
[/ QUOTE ]
https://www.grmotorsports.com/board/viewtopic.php?t=9881&highlight=phantom+grip
https://www.grmotorsports.com/board/viewtopic.php?t=7705&highlight=lsd
Careful!......How much research did you do?
Not that I'm some kinda know it all.....
I have never used one.
Just heard a lot of nasty stuff about them. /ubbthreads/images/graemlins/yesnod.gif
The consensus seems to be FWD ONLY!
And then only as a last resort.
Westfield_XI
Westfield_XI
I have heard somewhat the same, although the folks I have talked to run rear drive cars. I was worried about the metal to metal contact too, but since I had to reface the gears anyway to get the unit in, I polished both faces. The OEM spridget gears were terribly rough there, now they are smooth and shiney. Also if you read between the lines of the GRM forum, they have a lot more power than I do. 650hp vs 115hp!!!They are also using sticky slick tires with a lot larger contact area than my 5.00-15's, I don't expect a full LSD, then again, I didn't pay $1600 either.
Deleted member 3577
Actually, I'll be very interested to see how it works out for you.....
I have the same Spridget rear end.
If it does work well......
WTH.....So I blew what.....$1,200.00
No biggie
/ubbthreads/images/graemlins/cryin.gif
JerryB
B&B /Stefs in New Jersey
ARP
Pioneer Products
yes Jack I kinda go wound up on the diff deal. I prefaced the post with the spinning of tires = abuse.
Phantom grip.....the metal has to go somewhere even at 80 hp. A magnetic drain plug or two is in the cards?
Magnets.......was/is a place called wondermagnet.com or something of the sort??? neobdmenium magnets ultra strong...nice pieces to make a drain plug with. use the tubular ones.....easy.
W TR2/3/3A Differential cover torque Triumph 4
S TR2/3/3A when rebuilding a differential Triumph 9
B TR2/3/3A Possible differential problem Triumph 3
S TR2/3/3A Placing the differential on the frame Triumph 4
S Spitfire Differential clicking Triumph 6
CARSINC For Sale Sprite Differential Spridgets Classified 0
S TR2/3/3A old 4 bolt axle differential. Triumph 11
T Rear/Differential "Clunk" Austin Healey 2
G Spitfire Spitfire 1500 differential whining Triumph 6
B Midget Differential Capacity Spridgets 5
R Changing BJ7 Differential Ratio Austin Healey 10
R For Sale TR6 REAR DIFFERENTIAL Triumph Classifieds 3
A TR6 Installing differential and transmission Triumph 10
Sarastro TR4/4A Differential setup question Triumph 12
Ripper01 Sold- TR6 Differential drive Triumph Classifieds 1
Ripper01 For Sale Sold-TR6 Differential Triumph Classifieds 0
Michael Oritt Wanted 4.22:1 spridget differential Spridgets Classified 1
J TR6 TR6 Differential Rebuild question Triumph 6
J TR6 Differential / Rear Axle Triumph 1
71TR6 TR2/3/3A Locker Differential- I have one but what is it? Triumph 9
Got_All_4 TR6 Differential ID year & output shaft removal Triumph 11
Got_All_4 TR6 Differential side hub measurement Triumph 1
edkap2002 TR6 differential mounts, rear springs and shocks Triumph 1
glemon General Tech Differential flange removal Triumph 11
DrEntropy Wanted Later ['67~'68] differential. MG Classifieds 0
J Flaking Paint Inside Differential Austin Healey 6
P TR2/3/3A Another Differential Question Triumph 22
P TR2/3/3A Differential question Triumph 6
DrEntropy MGB Differential with too much lash MG 5
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
L Wanted Tr6 differential Triumph Classifieds 9
Lin Rear differential drain plug leak Austin Healey 16
P MGB Noisy Rear Axle / Differential MG 1
S TR2/3/3A Differential Gasket & Oil Leak Triumph 9
N Spitfire Changing Differential oil Triumph 14
R TR2/3/3A Sluge in Differential Triumph 21
J TR2/3/3A Differential Side Gear Backlash Triumph 3
J TR2/3/3A Differential Rebuild - Gear Markings Triumph 18
D Clutch-Type Differential Austin Healey 5
K TR2/3/3A Correct oil level for differential? Triumph 5
W Differential oil for 100/4 1954 Austin Healey 14
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
T Differential Pinion Bearings Austin Healey 0
H Third Member - Differential - Carrier Housing - Center Section - Gear Set Cleaning Spridgets 4
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
