TR2/3/3A Torque specification on large pitman arm nut
sp53
I have been looking around for Torque specification on large pitman arm nut, but cannot find any. I am thinking about 80 to 100 should work?
TR3driver
Great Pumpkin - R.I.P
Sounds good to me. I think Mark Macy gives 80 ftlb on his web site, but I used 100 and it seemed to work fine.
Carlbanan56 MGB Rear axel torque? MG 4
C Steering Arm Castle Nut Torque Austin Healey 5
P TR2/3/3A British High Torque starter Triumph 6
B Head Re-Torque Austin Healey 8
Joel Lester TR2/3/3A What final front suspension torque settings needed? Triumph 7
W TR2/3/3A Differential cover torque Triumph 4
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
M High-Torque Starter Austin Healey 10
AUSMHLY BJ8 Cylinder Head Re-Torque Austin Healey 26
Martinld123 High-Torque Starter Austin Healey 4
B TR4/4A High Torque Starter Wiring Triumph 9
B High-Torque Starter Rattling Noise Austin Healey 3
D 1.8 2007 Toyota Avensis Clutch & Flywheel Torque Settings? Other Cars 0
Lin Oil sump torque value? Spridgets 3
Lin Water Pump torque value for nuts on studs Austin Healey 1
Lin Gear Reduction High-Torque Starters: Inertia or Pre-engaged? Austin Healey 4
D Torque Sticks Restoration & Tools 6
J TR2/3/3A Head Torque - Wet or Dry Triumph 6
BJ8Healeys Torque on Midget rear wheel hub nut Spridgets 7
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
S Fan blade bolts - torque setting and thread-locker? Austin Healey 4
R Our J-H plan - torque specs needed! Other British Cars 2
S Locknut - rear wire wheel - torque spec? Austin Healey 15
Michael Oritt Torque values needed for 100 Austin Healey 5
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Michael Oritt Torque Setting needed Austin Healey 10
M Replacing front shocks, torque setting? Spridgets 2
G Torque for Front Pinion Nut Austin Healey 3
D torque values Austin Healey 2
K TR4/4A TR4A clutch pressure plate to flywheel bolt "torque value"? Triumph 2
Jim_Stevens TR2/3/3A Axle to leaf spring torque Triumph 2
T Thinking of building an adaptor to allow a torque wrench to tighten the knock-ons Austin Healey 32
69MGC MGC Rear Diff Cover Bolts Torque? MG 5
G TR4/4A ARP Bolt Torque Specs Triumph 10
K TR2/3/3A Steering box drop arm Nut torque value? Triumph 0
K TR2/3/3A Steering box rocker shaft Nut torque value? Triumph 4
tr3guy TR2/3/3A TR3 Fan Bolt Torque Triumph 3
Popeye TR4/4A Rear leaf spring bolt torque Triumph 11
M_Pied_Lourd TR2/3/3A Hi Torque Starter Repair Triumph 14
S Torque setting for U-Bolt nuts Austin Healey 12
M TR2/3/3A Has anyone put in a Hi Torque Starter from Moss? Triumph 21
Jim_Gruber Question on 948 Head Torque Specs - Before I break something please Spridgets 3
S Torque Range? Austin Healey 13
KVH General TR That Front Fan Dog Bolt Again--Torque It Triumph 7
K TR4/4A Gearbox front cover[Moss 848-000] torque spec? Triumph 1
Griz Manifold nut torque Austin Healey 11
B re-torque heads? Austin Healey 5
J Need dimensions for BJ8 PII radius [torque] box carpet flaps. Austin Healey 1
K TR2/3/3A Oil Pan bolt torque spec? Triumph 2
M TR4/4A TR4A - Torque the Front Suspension Trunnion Bolt! Triumph 5
