Too lean?
kozelding
I have a Falcon stainless steel exhaust on my BT7, which I think is fairly high-flow (at least it sounds loud, for better or worse).
The car drove fine, but on hot days, it was running rich enough that the exhaust fumes (especially sitting at a light) would kill you.
So I leaned out the mixture a tad, which improved hot idle, but now I get exhaust crackles and pops on deceleration (which I never had before).
Now on the scale of "Hey, the tuning's finally right!" to "Crap, I'm running dangerously lean!" what are the little backfires indicating?
TimK
When my exhaust started backfiring on deceleration, it was because the exhaust manifold gaskets needed replacing and the brass nuts needed tightening -- air was getting into the exhaust downstream and allowing the unburned exhaust gasoline to ignite.
bob hughes
I can echo Tim on this one, same thing happened to me, in my case the nuts were a tad loose for some reason. You can try tightening up the nuts insitu as it were without removing the carbs and see if there is any slack, can be a bit tricky.
As to the lean - check your spark plugs, they should be white - a light grey if you are lean, - then watch out for burnt valves a nut brown is nice. I am constantly being told that they Healeys run better when a tad on the rich side though so a darker shade of brown would be the best.
:cheers:
Bob
Marla TR4/4A Carbs too lean? Triumph 11
M Too rich -- too lean Triumph 14
J TR4/4A Exhaust a tad too loud... Triumph 6
jfarris Message too long error FORUM Navigation Questions 8
mctriumph TR2/3/3A The concept of too many Triumph 8
B For Sale Too many Healeys - BN2, BN4, BT6, BJ7 For Sale Austin Healey Classifieds 0
KVH General Tech Flywheel Bolts Too Long For Main Seal Triumph 13
R For Sale Conundrum - Too Many Bugeyes Spridgets Classified 1
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
K TR2/3/3A Front wheel bearing felt seals too large? Triumph 9
M TR6 76 TR6 Brakes too tight Triumph 10
B TR4/4A Too Many Wires? Wiper Motor Triumph 9
S TR2/3/3A Exhaust system - It hangs too low no matter what I do Triumph 15
M 1275 too high? Spridgets 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
JPSmit Pre-War Is it too early to write Santa? 1933 MG J1 MG 13
CJD General TR Too Rude Triumph 13
AUSMHLY 64 front end too high Austin Healey 14
S TR2/3/3A OMG problem—the doors are too tight Triumph 12
T TR2/3/3A Turn Signals Blinking too fast Triumph 2
M Fat Feet hitting too many pedals Austin Healey 23
DrEntropy MGB Differential with too much lash MG 5
Got_All_4 TR6 TR6 engine rebuild. Too tight? Triumph 23
S TR2/3/3A New shocks too short? Triumph 7
BoyRacer Fuel tank sealing rubber is too thick Austin Healey 3
HalLucy Post-War Other Renown - Idle too fast Triumph 5
TRMark TR4/4A Seal too large for Surrey backlight Triumph 8
J TR4/4A Too hot to drive a convertible Triumph 14
S TR2/3/3A Too much fast idle, not enough choke? Triumph 0
TomMull TR2/3/3A New Top Too Tight Triumph 14
Jim_Gruber What Now, new gas tank filler neck is about 1/2-3/4" too short Spridgets 19
warwick-steve How low is too low? [spring question] Austin Healey 19
D TR4/4A flywheel bolts maybe too long Triumph 15
kennypinkerton MGB Are my wheels too far gone? MG 8
wkilleffer MGB Fitting a new top to a 74 MGB- how tight is too tight? MG 23
3798j Boomers Too Old for Sports Cars Other Cars 8
PC Dang, that was too good to be true... Restoration & Tools 3
tr3guy TR2/3/3A New Wheel Cylinder too large Triumph 7
A rear brake drum too tight after rebuild Austin Healey 3
Jim_Gruber Bullet Connectors are too large to fit Tail Lamps on BE Spridgets 8
Got_All_4 TR2/3/3A Tr6 a type overdruve in my tr3 too long Triumph 10
TomMull Air Compressors, how much is too much? Restoration & Tools 7
Trevor Jessie Waaaay too much body roll Spridgets 14
Rut MGB Too many cars MG 31
KVH General Tech Transmission Drain Plug Too Tight? Triumph 5
T TR2/3/3A Is 5.5 lbs too much fuel pressure? Triumph 9
Martinld123 Why too much valve clearance after adjustment? Austin Healey 2
KVH General TR How Tall is Too Tall for the TR4? Triumph 3
E Spitfire How tall is too tall? Triumph 21
DornTRoriginal General Tech The Devil is in the Details! Am I asking too much? Triumph 21
