The DPO blues
MGBGT_noob
I've run into my first DPO roadblock, in the process of disassembling my car.
Apparently, during a previous accident, the two bolts inside the grille opening, that connect to the fender, riped out of the engine bay side panel.
If I wanted to fix such damage, I imagine I'd weld a patch onto the engine bay panel, drill new holes, and bolt a new fender on normally. Mr. DPO decided to WELD THE NEW FENDER DIRECTLY TO THE PANEL!!!!
I tried running a reciprocating saw through the joint, to separate the welds (one at the former site of each bolt hole) but they proved tougher than I expected.
Anyone got any suggestions for eradicating welds in tight spaces?
Ed Kaler
<div class="ubbcode-block"><div class="ubbcode-header">Quote:]
Anyone got any suggestions for eradicating welds in tight spaces? [/QUOTE]
Any chance of getting to them with a 90deg drill and a hole-saw, /bcforum/images/%%GRAEMLIN_URL%%/wall.gif
what-ever-your-name-is???? /bcforum/images/%%GRAEMLIN_URL%%/hammer.gif
/bcforum/images/%%GRAEMLIN_URL%%/cheers.gif
Ed
MGBGT_noob
MGBGT_noob
/bcforum/images/%%GRAEMLIN_URL%%/yesnod.gif hmm, hole saw, that's just crazy enough to work!!!
I just hope the pilot drill doesn't ruin the threads in the fender.
Ed
prometalshop
Member
Hi Noob
Turn the drill around so the cutting edge is facing in. /bcforum/images/%%GRAEMLIN_URL%%/smile.gif
Banjo
prometalshop said:
Hi Noob
Woulden't that put a hole in your drill?
(ducks and runs) Sorry coulden't help it. /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif
prometalshop
Member
I SO deserved that one Banjo /bcforum/images/%%GRAEMLIN_URL%%/lol.gif
mccalebr
If you have a compressor you might want to pick up and cheap air hammer. They normally come with four or five attachments; the straight chisel and the spot weld breaker (straight chisel with a V groove in the center) are the two I use most often.
About $20 at your local builder's mart or on sale for the ridiculously low price of $4.99 at Harbor Freight:
https://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=32940
Ray
jlaird
And boy do they work.
MGBGT_noob
MGBGT_noob
Ray
I'll see if they have them in stock at my local H-F, tomorrow.
/bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif I get to buy more tools /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif /bcforum/images/%%GRAEMLIN_URL%%/grin.gif
MGBGT_noob
MGBGT_noob
Success!!! [was: The DPO blues]
The Harbor Freight air hammer worked like a champ. I got the fender off, with only slight damage. Hopefully, I can patch up the tears, and reuse this fender.
tony barnhill
Great Pumpkin - R.I.P
Re: Success!!! [was: The DPO blues]
Does that GT have a hole in its roof?
MGBGT_noob
MGBGT_noob
Yeah, I guess you could say that. :lol: :lol: :lol: :lol:
Don't forget "the Beast of the East"
mccalebr
Great.
Tears do happen but can be minimized. Watch carefully to see if the weld is being cut or pulled by the chisel. If it's being cut a couple minutes with the hammer and dolly is usually all that's needed to straighten out the area. If it's pulled, a soon as a tear begins, back out the chisel and, if possible, reinsert at 90 degrees to the first effort; repeat two more times. Normally, a small pencil eraser hole is all that will result; this is no more than drilling for a plug weld and is is usually easily filled.
Glad you had success!
Ray
Jarhead
Are you taking this one down to a shell? Im going to have to replace both rockers, the wheel horns and probably the front fender attachments next to the wheel horn. They are not totally gone but there is some definite repair needed.
MGBGT_noob
MGBGT_noob
I plan to strip it down to the point where I can get it blasted, before I try to get the new roof welded on.
For a car that has obviously spent so much time outdoors, unprotected, and didn't receive the kindest of treatment before it went out to pasture, I've found surprisingly little "serious" rust. But, the media blaster may reveal more than I can see in it's current state.
vping
Bronze
What did you wind up doing about the roof?
MGBGT_noob
MGBGT_noob
A local club member has parted out a number of GTs. He saved the roof off of one, and I just need to wait for last year's bonus to come in, before I buy it off of him.
Thanks for offering before.
PeterK General TR Dumbest DPO Triumph 37
TRMark Being my own DPO, stripped front sealing block Triumph 6
dklawson Spitfire Spitfire Rear Wheel Flanges-Common Problem or DPO? Triumph 7
RickB Weird DPO wires heating up really hot Spridgets 16
D DPO Feat Triumph 5
Stewart What is this? DPO or factory? MG 17
Stewart Anyone Id this part most likely dpo related MG 10
D More DPO stuff Triumph 7
1965_MGB DPO Rant MG 5
J What was the DPO doing? Austin Healey 7
T More DPO Pedro Bits Triumph 7
PATR8 Wedge TR7 DPO forgot the mention a few things Triumph 9
T Just Venting-DPO Pedro Triumph 8
PATR8 The D in DPO = Devious Triumph 4
Tim Tucker DPO brilliant ideas... Triumph 11
malice DPO, Suspension, Etc.... Triumph 11
T More of DPO Pedro removed Triumph 18
Atrus DPO does well for me! Spridgets 11
bugimike Another DPO sufaces Spridgets 8
L DPO means I need your help. Have pictures! Spridgets 6
kyreb1862 DPO Legacy MG 18
tony barnhill DPO's Again... MG 16
tony barnhill Love the DPO, Hate the act... MG 36
jaybird OMG! It IS DPO, IT IS! MG 21
Alan_Myers D'oh! DCO v. DPO Triumph 3
jaybird You Might Be The Victim of A DPO** If… MG 0
I DPO Gems MG 1
T The ultimate DPO MG 6
Joe Reed DPO: What to expect? MG 6
G Bellhousing Blues Austin Healey 12
R Steering wheel blues Spridgets 7
stretchit2 Oh No I Didn't or the Dropped Not Blues Austin Healey 6
jmwuva05 H1 blues Spridgets 5
B Hardtop blues Restoration & Tools 2
bigjones Tow truck blues - good analysis for you to ponder Spridgets 33
PatGalvin Wheel bearing grease seal blues - they continue Triumph 15
Tabcon New Starter Blues Triumph 2
bugimike The new hood blues! Spridgets 15
G "Stormy Monday Blues".... Triumph 7
2wrench Got the Bently Beckoning Blues Triumph 22
L Overdrive Blues Triumph 19
G Starter Blues Triumph 18
Andy Blackley Wheel bearing blues Triumph 5
kcbugeye1275 Salvage yard Blues Spridgets 0
R6MGS Cadillac Blues.... Other Cars 10
P Freeze Plug Blues Austin Healey 12
mcguijo TR2/3/3A TR3 Transmission Blues Triumph 16
Morris Old Head Gasket Blues MG 9
E Ignition Blues MG 13
mylillooker I got the Eletric Blues Spridgets 9
