TR4/4A Test fitting TR4a rollbar - some advice please
tdskip
Hi guys - so I think I mentioned I picked up some roll-bars at a local swap meet. Here are some pictures of the bar I <span style="font-style: italic">believe</span> is correct for the TR4. I know this isn't the exact location but I want to make sure it is the correct bar and I can securely mount it based on the geometry.
Can you review the pictures and let me know if it looks correct for the TR4?
Thanks!
kodanja
Thats similar to the location of the mounting in my TR6.
I put in 1/4" reinforcment plates on both sides of the mounting holes.
(I know its not fail safe, but were driving rolling coffin's anyway)
Just be sure that your seat can go all the way back prior to making any bolt holes
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
KVH General TR Overdrive Pressure Test Triumph 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
T TR2/3/3A 4th Test drive Triumph 12
S TR4/4A How to test Overdrive out of the car Triumph 45
P TR6 Latest compression test Triumph 11
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
gbtr6 TR6 Test starter system with engine out? Triumph 16
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
S TR2/3/3A Test an overdrive trans. Triumph 6
T TR6 TR6 compression test Triumph 12
D LSR test run Racing 2
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
C High test or regular gas? Jaguar 4
C How to test shocks? Austin Healey 7
M Compression test results Austin Healey 11
NutmegCT TR2/3/3A Sports Cars Illustrated TR3 road test Triumph 17
J MGB Smog test fail MG 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
Lukens TR2/3/3A Is there a subforum that I can send "test" posts? Triumph 3
NutmegCT General Tech Condenser test? Triumph 38
B test a wiper motor? Spridgets 13
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
G TR4/4A tr4a vacuum test Triumph 13
