TR4/4A How to test Overdrive out of the car
shoopal
Hi all
I am wondering if it is possible to check the OD without it being hooked up to the motor.
Thanks
TR3driver
Great Pumpkin - R.I.P
I use my 1/2" drill motor as a power source. I forget the size offhand, but I've got a short length of straight radiator hose that just fits over the splines on the input shaft, and the nose of the drill chuck; plus a hose clamp for each end. The gearbox sits on the workbench in a crude cradle cut from scrap lumber, while the drill is held loosely in the bench vise. A tie wrap for the speed control on the drill, and a small 12v battery to power the solenoid. (My bench power supply won't deliver the 20 amps or so to activate the solenoid on an A-type).
Not a 100% check, as the drill motor doesn't turn very fast (850 rpm), but good enough to cover most things, including the all important pressure check. I've been keeping my eyes open for a cheap DC motor so I can try running it up to 5000 rpm next time, but haven't found one yet.
There are some more sophisticated setups shown in the articles at
https://www.buckeyetriumphs.org/technical/AOD/AOD4/AOD4.htm
and
https://vintagetriumphregister.org/maintain/TransRebuild/OverDriveA02.pdf
S
shoopal
Thanks. A lot of information there. I guess that I will drain and replace the 90 wt. and clean or replace the screen
Then I think that I am going to put the motor and Trans into the car and test drive it before I do the tunnel. (that yoke thing is a real pain in the ***.)
If there is some problem, then I can get it back out pretty easily and do the diagnostics as per the instructions.
Thanks for the links.
CJD
Don't even need the hose...there is a perfect rod machined into the end of the output shaft. The drill will chuck right onto it! The OD runs off the pump, which runs off the output shaft, so it works perfectly. The tranny doesn't really care which end you are turning...it just figures it's a downshift...
Important safety tip...be sure to flip the drill to turn counter clockwise! It will jam the sprag clutch if you spin the other way.
Geo Hahn
Haven't tried it on my OD box, but a motor salvaged from a Maytag washer works well and offers two speeds (and a rinse cycle):
TR3driver
Your choice, of course. But I would definitely recommend checking the pressure with a gauge before buttoning things up. Low operating pressure can cause subtle problems that become bigger problems later on (like the OD clutch slipping only when hot and climbing a hill) or intermittent shifting problems.
Geo Hahn
... If there is some problem, then I can get it back out pretty easily...
Pretty easily? -- you must be younger, stronger, thinner and more agile than me or possibly you just have a higher threshold for pain & strain.
The solo R&R of an OD is doable, but not something I want to do more than absolutely necessary.
S
shoopal
So let me get this straight. Chuck in a drill on the output shaft. It can stay in neutral? Rev it up. Measure pressure. Put it into gear (which one?) Energize Coil. check for change in input shaft rotation (slow down?) and weird noises. Is that it?
S
shoopal
So let me get this straight. Chuck in a drill on the output shaft. It can stay in neutral? Rev it up. Measure pressure. Put in gear (which?) Energize Coil. check for change in input shaft rotation (slower) and weird noises. Is that it?
TR3driver
Pretty much. 4th gear will do (but any gear would work). I'd also check that the pressure comes back up where it should be when you engage OD.
KVH
I'm in the minority here, for some reason, but none of the above would spin my rebuilt overdrive on the bench. I had to buy a 2 HP electric cooler motor with a pulley bolted to the rear flange.
TR3driver
When I had that problem, it turned out that the clutch linings had swollen, probably from long exposure to solvent. (Long story, but I was substituting the clutch plate from another OD that had accidentally been left in the solvent bucket for a few years.) The OD clutch was dragging when in direct drive.
It should turn easily. The only drag comes from the pump, and it should take practically nothing to turn before the pressure gets built up (and not much even when the pressure is up).
gbtr6
Nice setup. I like the custom shift lever. It's a Craftsman so you know it will last.
Perry
S
shoopal
Hey Mr. Pumpkin
I couldn't chuck my cordless on to the tailshaft but I can chuck it on to the input shaft. All full of oil, replaced front seal just in case and now I'm ready to spin it up by the input shaft to test the pressure. What direction does it spin? The motor turns CCW looking at it from the rear. so it seems to me that the input shaft should turn CW looking into it from the bell housing.
Is that right or am I going slowly insane
TR3driver
That seems right to me.
That's a bearing surface you're grabbing, though. Be sure you don't damage it!
KVH
Here's what I have today, with my transmission and OD out of the car and on the bench. My OD was working great, but whether I've got bearings misaligned or whatever here's something maybe Shoopal can test as well: When grabbing the rear flange and spinning it by hand, does it continue to rotate once you pull your hand away following a spin? Mine stops dead right there. There's no residual spinning from the force of my hand. The foot pounds of pull to rotate the rear shaft is about 3 to 4.
CJD
With new seals I would expect the flange to not continue spinning.
I also would be reluctant to chuck the input shaft. Better to shift back to the hose idea. Clamp the hose to the shaft, and the other end to a bolt that you can chuck.
S
shoopal
Hi. I don't have a torque wrench that goes down to 3-4 ft lbs however I did a little test to estimate the torque required to spin the tailshaft.
Let me start by saying that my OD has not been rebuilt but came from a donor car with about 50,000 miles on it. It will not spin after force has been released which I would not expect anyway. There is a lot of friction in there. By the way you did not indicate if the OD was attached to the gearbox when you were testing it. If not, none of what follows means anything.
First I tested it in neutral which should give the lowest readings. I clamped an 18 oz vise grip to the tailshaft knob and the weight of the vise grip was enough to start it turning. Measured 6" from jaw to end. Assuming that the vise grip weight is uniformly distributed then the 18 oz at 3" would result in .28 ft-lbs. In reverse I had to clamp it on the very edge of the flange so the calculation was 18 oz at 1 ft so that the calculation results in .56 ft-lbs. Both measurements far below what you are reporting.
On the other issue of spinning the tranny via the input shaft, I get your all concerns, unfortunately (my wife always complains about my lack of impulse control) I already did it. I examined the input shaft just now and it doesn't have any scars from the operation but I won't do it again (I promise, ha-ha). I still need to borrow trans pressure guages from my friend.
One last question for general discussion. The OD manual that I downloaded (https://www.tonydrews.com/Overdrive/A-type OD manual.pdf) refers to the correct positioning of the valve control lever. That is when the solenoid is actuated, the 3/16" hole on the other side has to line up with the hole on the OD body. Mine does not as the lever goes past the body hole. Should I readjust this?
M Overdrive Pressure Test Austin Healey 2
KVH General TR Overdrive Pressure Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
S TR2/3/3A Test an overdrive trans. Triumph 6
S Spitfire 76 spitfire overdrive test question Triumph 5
C How to test overdrive throttle switch and need arm Austin Healey 13
T A type overdrive repair and test Triumph 9
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
T TR2/3/3A 4th Test drive Triumph 12
P TR6 Latest compression test Triumph 11
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
gbtr6 TR6 Test starter system with engine out? Triumph 16
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
T TR6 TR6 compression test Triumph 12
D LSR test run Racing 2
T Wedge Riddle me this guys | TR8 SMOG test issue Triumph 13
C High test or regular gas? Jaguar 4
C How to test shocks? Austin Healey 7
M Compression test results Austin Healey 11
NutmegCT TR2/3/3A Sports Cars Illustrated TR3 road test Triumph 17
J MGB Smog test fail MG 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
Lukens TR2/3/3A Is there a subforum that I can send "test" posts? Triumph 3
NutmegCT General Tech Condenser test? Triumph 38
B test a wiper motor? Spridgets 13
