Test Drive I Don't Wanna Mess it Up
sail
So did the gearbox myself and think OD is good and wanna see if what I did is ok so fill with oil and go for a drive? Nothing will be wired. What can I mess up that I have not already?
Moseso
Never, never, never ask that...
Do you have a 1/2" chuck drill? The pilot end of the input shaft is 1/2". You can chuck your drill motor onto that, spin-up your tranny (CLOCKWISE, the same direction your engine turns -- THIS IS IMPORTANT) on the bench, and check everything, including OD function.
It would be nice to have one of those OD pressure test gauges, but it can be done without.
If it all looks (sounds) good, then mate it to the motor and take your test drive.
Moseso
sail said:
A guy just gets kinda anxious.
I completely understand that!
Never asking that other thing has to do with the supernatural ability that question has to show you just exactly what else you could mess up -- often, fairly quickly. Bad Ju-Ju!
TR4nut
It's definitely worth a bench test first - unless you have a much stronger back than I do and enjoy pulling the trans in and out of the car!
I just bench test the od I plan on putting in the 3A - looks pretty good, but the gauge gave me 300 psi which I think might be a little low - for me the testing was definitely worth it.
T TR2/3/3A 4th Test drive Triumph 12
RickB 1980 MGB on test drive suddenly loses electrics and dies - what to look at? Spridgets 46
A test drive and oil pressure Triumph 8
drooartz Progress: test drive! Spridgets 11
6 test drive after 2 years Triumph 4
RickB 1.5 M test drive really had me laughing out loud!! Spridgets 14
LastDeadLast Finally!! Test drive HVDA 5-speed install. Triumph 13
zimmy yesterdays drive test results Spridgets 0
Bret Zed 4 test drive! Other Cars 5
jlaird Test drive Spridgets 7
Baz Test drive.....problems......what now? Spridgets 5
B short test drive? Triumph 6
A XK150 FHC Test Drive Jaguar 1
B Hot Drive Test--Results Austin Healey 2
Steve Test Drive British Motor Corp 2
petnatcar Compression Test Record Form Austin Healey 0
kodpkd Compression Test Results Austin Healey 1
M Overdrive Pressure Test Austin Healey 2
RJS General TR Oil Pressure Gauge - Test Triumph 11
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
PAUL161 T-Series 5 Speed Road Test MG 25
Rob Glasgow First Test Austin Healey 6
K TR2/3/3A Test Triumph 0
glemon Test FORUM Navigation Questions 4
AUSMHLY HD8 drop test time in seconds Austin Healey 3
AUSMHLY Compression test results Austin Healey 17
HealeyPassion EFI AH Initial Test Day... Austin Healey 6
Michael Oritt Every ride is a test ride Austin Healey 9
roscoe Leakdown test [long read] Austin Healey 11
Y Passing the smog test MG 17
KVH General TR Overdrive Pressure Test Triumph 17
Jeepster BJ8 Servo/ brake booster test Austin Healey 1
D Test image post FORUM Navigation Questions 1
D Lilly test runs Austin Healey 4
F TR2/3/3A Compression Test Triumph 13
M Carb emission test Austin Healey 5
RJS General TR Head Gasket Test Fit Triumph 5
Tinkerman TR2/3/3A SU H6 Rebuild Bench Test Triumph 3
KVH General Tech Leak Down Test Triumph 17
T TR2/3/3A How do I test overdrive relay diode jumper? Triumph 2
T TR2/3/3A SU Piston Drop Test Triumph 4
Steve1970 TR6 Carb air piston test, still results in stall even when adjusted rich Triumph 11
toysrrus TR2/3/3A How to test fuel gauge & sending unit? Triumph 10
S TR4/4A How to test Overdrive out of the car Triumph 45
P TR6 Latest compression test Triumph 11
gbtr6 TR6 Test starter system with engine out? Triumph 16
NutmegCT Memory test Other Cars 9
J TR6 Test 75 TR6 Hazard Switch? Triumph 12
S TR2/3/3A Test an overdrive trans. Triumph 6
T TR6 TR6 compression test Triumph 12
