TR5/TR250 TC2500 tappet clearances?
Wombat
Member
I should have asked this question at the same time as asking about torquing the head bolts (silly wombats aren't very good at thinking ahead
What are the cold tappet clearances for a TC2500?
Thanks again!
piman
Hello Wombat,
the cold clearance is 0.010" inlet and exhaust.
You can use the thirteen rule but Triumph issue this table:-
Valves 10 & 12 fully open adjust 1 & 3
2 & 5 " " " 8 & 11
7 & 9 " " " 4 & 6
1 & 3 " " " 10 & 12
8 & 11 " " " 2 & 5
4 & 6 " " " 7 & 9
Alec
[ 01-08-2004: Message edited by: piman ]</p>
W TR5/TR250 points gap for a TC2500? Triumph 2
W TR5/TR250 Torque setting for TC2500 head Triumph 3
Celtic 77 MGB Tappet breather to Weber downdraft MG 4
S TR2/3/3A tappet assembly Triumph 10
T Modern Oils for Our Flat Tappet Engines Austin Healey 26
T Modern Oils for Our Flat Tappet Engines Spridgets 7
G Tappet Noise Austin Healey 8
M TR2/3/3A Tappet Clearance confusion Triumph 3
B TR4/4A Tappet wear pattern inspection - normal or not ? Triumph 13
Rut Brake adjuster tappet Spridgets 18
HealeyRick Rear Brake Adjuster Tappet Needed Austin Healey 2
T SPQR Tappet adjuster, Click Adjust Austin Healey 1
E Good tappet cover Austin Healey 5
L Simple fix for leaky tappet cover Austin Healey 0
T Oil leaks under carb are - tappet inspection plate Spridgets 6
memphis Tappet Tool Austin Healey 10
M TR2/3/3A TR3 Tappet Triumph 4
AH100M BN2 Tool kit spark plug/tappet feeler gauge Austin Healey 7
KVH Another Tappet Question Triumph 9
vping Tappet cover gaskets - Need help! MG 6
Baz Tappet Inspection MG 7
MadMarx Tappet - flat or domed? that's the question Triumph 5
L Tappet Inspection Austin Healey 8
V TR6 TR6 Flat Tappet Triumph 12
Wana Tappet clatter? Austin Healey 3
vping Tappet cover gaskets and.... MG 1
red57 Rod Bearing Clearances Austin Healey 4
Bob_Spidell Gaskets and clearances Austin Healey 5
E TR6 General Inquiries.....Camshaft and valve clearances Triumph 3
A TR2/3/3A Tr3 / 4 piston clearances Triumph 7
R Adjusting Valve Clearances Triumph 13
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
Gliderman8 TR6 Setting TR6 valve clearances Triumph 19
G Torquing rocker pedestal changed clearances Triumph 1
Moseso Rocker Arm Clearances Triumph 4
Morris Bearing clearances and oil pressure Spridgets 22
19_again clearances and gaps MG 5
K TR6 TR3 Rad......TR6 Fan Clearances Triumph 5
Patton Rocker Arm Clearances too Large Symptoms Austin Healey 5
