Cork seems to age better in the engine bay, which is why they don't make valve cover gaskets in rubber. I usually put my cork side cover gaskets on dry and have no leaks, but if you have an imperfect surface they will definitely let a bit of spray out. A bit of Hylomar sealant on the cork gasket certainly won't hurt anything, but don't use torque to cure the leak or you might make it worse! Remember the cover plates require very little torque, and if too much is administered the cover will bend. It happens easier than people realize and then they can't figure out why they constantly suffer leaks! Another cause of leaks is excessive crankcase pressure caused by a clogged breather and / or PCV valve.
